Which Front Fascia Would you prefer?
Old Nov 20, 2010 | 11:46 AM
2jcoupe's Avatar
Hey guys my 95 300 is about to undergo a na -TT swap and i need to decide on a new front fascia for the car to house the front mounted inter cooler and piping. I'm stuck between the 99 Jspec front fascia,
The Greddy Gracer Front fascia,
And the stillen type 3 lower lip for the twin turbo model if i decide to stay with the stock dual side mounted inter coolers.
Just looking for some opinions on whats more aggressive in YOUR eyes. Thanks alot guys
-2jcoupe
Old Nov 20, 2010 | 02:54 PM
J-spec and **** FMIC's on a z32.
Old Nov 20, 2010 | 06:42 PM
ZguyECV's Avatar
I’d go with the j-spec, looks cleaner and more aggressive. I dnt think that stub nose look does Justice to any car.
Old Nov 20, 2010 | 06:55 PM
2jcoupe's Avatar
The J-spec does look cleaner than the greddy gracer but what aboutt the stillen type 3 lip????
Old Nov 21, 2010 | 09:48 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
I like the Stillen Type III, and you'd be an idiot to do a FMIC.
Old Nov 21, 2010 | 10:32 AM
BlueKitsune's Avatar
Intrawebz Wizard
I vote for the J-Spec. And whats wrong with a FMIC? I was thinking of getting the FMIC kit from SZ seeing as how my 300ZXTT Doesn't have any AC at all. The SZ site isn't working for me right now else I'd post a link.
Old Nov 21, 2010 | 10:42 PM
The one Specialty Z sells (TDM Works') is kind of the exception - it's a properly designed FMIC (as opposed to almost all others, which negate the natural design of the VG30DETT - do your research to see why because I'm not going to type it out yet again simply because you're too lazy to do so), but it still is a HUGE restriction of airflow to your intake (you'd have to relocate to resolve that), your oil cooler (you'd have to relocate to resolve that), and your radiator (even without an AC condenser, the FMIC is still more restriction).
So consider this. You could get Stillen or Ash SMICs and that's it... or you could get a FMIC + upgraded radiator + relocated oil cooler + relocated intake to achieve essentially the same horsepower gains. The TDM Works FMIC is only needed for insanely powerful Z32s (Greg's Z runs 9's in the quarter... and he was running low 10's with side mounts before his newest build, so SMICs are MORE than sufficient for almost all builds).
In the end, a front mount usually ends up being a cosmetic mod, because SMICs will serve just as well, and often better (in the case of all FMICs other than TDM Workds), while costing less.
Old Nov 22, 2010 | 06:35 AM
Intrawebz Wizard
Hmm. I see. I'll have to decide carefully. Its really going to depend on if I can get my AC repaired with parts from the front clip or not. I was already going to grab an upgraded radiator that also has the engine oil cooler built into it, along with a twin pop intake setup. I'd just put the air cleaners down close to where the SMICs would be.
Hmm.... time for more research again lol
Old Nov 23, 2010 | 08:17 AM
2jcoupe's Avatar
Orly? I was under the impression that the front mounted inter cooler was the way to go. But If the smic will perform just as well than thats less money to worry about :-D BUT I'm still stuck between decisions on which fascia i want. I also recent discovered a front lip offered in japan that I really like.
Old Nov 23, 2010 | 04:44 PM
That's why people should do much research before ever modding their car. Saves them from wasing money on inferior products.
Old Nov 23, 2010 | 05:31 PM
Intrawebz Wizard
Hey at lest I was looking at the only good FMIC lol
booschi
Sep 10, 2008 11:58 AM
kevtt
Mar 14, 2006 08:35 PM
WichitaZRide
18
Jul 25, 2005 02:10 PM
iminsideurZ
Jun 30, 2005 11:58 PM
