engine mounts
Old Apr 24, 2009 | 09:56 AM
DropTopTwin's Avatar
engine mounts
Anybody ever change out their old mounts? If so did you go OEM or aftermarket?
Old Apr 25, 2009 | 06:16 PM
napoleonzheking's Avatar
F5 Hero
I got OEM.
Old Apr 26, 2009 | 05:52 AM
Why did you go OEM instead of aftermarket? Some advertisements are showing with cars over 450hp, you should upgrade to aftermarket. You're thoughts on that?
And thanks for your reply.
Old Apr 26, 2009 | 10:04 AM
b300z's Avatar
caught the z fever
aftermarket ones (noltec) suck
your only real other option is the ford mounts.
Old Apr 26, 2009 | 11:37 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
Let me repeat what was just said. :ahem: :::clears throat:::
NOTLEC SUCKS
Get OEM, or there's also a writeup on retrofitting Ford (F150?) motor mounts to work.
And let the record show that I had 550bhp with OEM mounts, no problems.
Old Apr 26, 2009 | 12:10 PM
KasbeKZ's Avatar
Pr0n Addict
had? is the car already disassembled?
Old Apr 26, 2009 | 12:22 PM
No, but it's definitely not making 550bhp right now. LOL
Old Apr 26, 2009 | 12:38 PM
its broked! whats wrong with the aftermarket ones? i just got poly mounts (which taking out the old rubber and putting those poly ones into the mounts SUCK) for my talon and everyone claims they are amazing for wheel hop in the AWD but make the car vibrate like a beast! which i know mine will with full poly mounts and the removed balance shafts. ugh
Old Apr 26, 2009 | 01:07 PM
The Noltec mounts for Z32's routinely fall apart.
Here's a crappy pic of one doing just so...
Some links with quotes:
http://www.twinturbo.net/net/viewmsg...&forum=general
less than 50 miles on it, parked it 4 months, moved the cars, found the noltec mounts dissintegraded on the garage floor
We have recently discovered on one of our personal cars that it is possible to "melt" the Noltec Urethane Motor mounts.
Noltec advises to always run the proper heat sheilds on manifolds and they are not be interested in covering any warranty claims against their products due to heat damage. Unfortunately, there are plenty of Z32 guys with upgraded turbos or manifolds no longer using these sheilds.
Old Apr 26, 2009 | 04:41 PM
prothane FTW!
280ZXgirl
Mar 17, 2006 12:46 AM
roninjiro
Oct 10, 2004 08:11 AM
91zxtt
Aug 31, 2004 11:52 AM
91zxtt
Aug 3, 2004 12:41 PM
Vman
Jun 4, 2004 01:11 PM
