coolant leak under right turbo
Old Jul 18, 2009 | 08:13 PM
jdb96TT's Avatar
there are 2 coolant hoses going to the right (passenger) turbo. I had already replaced one, the easier one to get to. The other one blew the other day and short of removing the plenum I can not see how to get the old one off. Any ideas?
Old Jul 18, 2009 | 08:52 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Pull the motor.
Old Jul 20, 2009 | 08:00 PM
SloppyGoat's Avatar
Yeah, didn't you know you have to pull the motor to do anything to those cars?
Old Jul 28, 2009 | 11:26 AM
napoleonzheking's Avatar
F5 Hero
Hire a midget (or carney) to work for you.. small hands... Get one of those midgets that i see on smallest people in the world on TLC... they can easily probably do it....
Old Jul 28, 2009 | 03:10 PM
Goofyz's Avatar
What do you mean by right side?
Driver side or passenger?
I found that although nearly impossible for normal man hands to get in there it is possible with a pair of women's hands. Best if still on a woman. But if you need just one more inch of clearence you can drop the tranny, unbolt the motor mounts and jack the engine up 1-2 inches (tilt it forward) without causing any harm. That is if you don't want to take the engine out and replace all the hoses and probably the wire harness cause all the plastic bits are so brittle the break when you get near them with a flat tip screw driver... Zlover will tell you that he can pull a motor in a couple-few hours, but that's if you know what you are doing and have done it a couple-few times before. either way, good luck.
I was able to replace the coolant lines (passenger side) but I had to cut the old ones off to do it and yes, I ended up with lots of cuts and bruises on my hands.
emann029
Jul 28, 2009 11:27 AM
vrocious
Oct 23, 2008 11:08 AM
oldschool
Aug 15, 2005 10:40 AM
zfanman
Jun 24, 2005 01:56 PM
quansta
Nov 20, 2002 09:35 AM
