check out this intercooler piping
Old Jan 7, 2007 | 03:25 PM
emo236's Avatar
confuzed member
Interesting design...I wonder if it helped overall gains at all. I'm guessing it's custom.
http://www18.ocn.ne.jp/~mamiana/niss...ma-photos.html
Old Jan 7, 2007 | 03:28 PM
are you talking about that balance tube like guy between the piping? or am i missing something?
Old Jan 7, 2007 | 03:44 PM
emo236's Avatar
confuzed member
no the pipes that go from the turbos to the intercooler(s) are mandrel bent at a different angle than stock or even the usual aftermarket pipes. I wonder why the guy did this. I just thought it was interesting.
Old Jan 7, 2007 | 06:55 PM
mhmm... i did not catch that... must go back to site now...
Old Jan 7, 2007 | 06:58 PM
so i calculated it... and they are selling that car for only 11,000 US dollars. you should buy it
Old Jan 7, 2007 | 07:57 PM
b300z's Avatar
caught the z fever
probably minimal gains.
there was someone on tt.net who fabbed up custom piping and shortened the route drastically
Old Jan 7, 2007 | 09:53 PM
emo236's Avatar
confuzed member
the website that was from actually had a bunch of very inexpensive Jspec cars. The prices are before shipping and legalization. You could also get skylines for around that same price.
Old Jan 9, 2007 | 08:51 AM
Riz Z Speed's Avatar
Administrative Brown Guy
i think you're mistaking the tube that runs to the intakes as a balance tube. looks more like a nitrous feed to me. the plenum already incorporates a balance tube so having one there would be kinda redundant.
Old Jan 9, 2007 | 11:37 AM
Milo (SZM mag)'s Avatar
Wide Body Magazine Guy
Very nice.
Old Jan 9, 2007 | 12:48 PM
emo236's Avatar
confuzed member
no, I was talking about the pipes that go from the turbos to the intercoolers. Not the balance tube. And the balance tube where this guy put it is pretty common on cars with FMICs. The FMIC disrupts the air going into the intake, so the extra balance tube there is supposed to smooth it back out.
Old Jan 9, 2007 | 03:08 PM
Now that we are on it. You think a custom, larger diameter balance tube would ever do anything? I wouldn't think so...but thought I would bring it up for argument sake.
Old Jan 9, 2007 | 04:20 PM
emo236's Avatar
confuzed member
I wouldn't think so. What would be the reasoning behind it? I can see how an extra balance tube before the manifold might be able to do something, but not a bigger diameter balance tube.
Old Jan 10, 2007 | 11:32 AM
Yup, I'd agree. I have seen the pre-tb balance tube on a lot of engine from the Japanese crowd...even on Hyper Rev there are a few instances of it.
Old Jan 13, 2007 | 08:05 PM
91zxtt's Avatar
If the tubes that were used in this car uses fewer sharp bends; which it looks like it does, and it uses larger diameter piping, then it would allow a greater volume of air to flow through the pipes at a greater speed. It would be a performance upgrade. I'd be interested in seeing the pre and post install dynos.
Old Jan 13, 2007 | 08:08 PM
bardabe's Avatar
Bad Speller
What he said
Old Jan 15, 2007 | 10:45 AM
v0va's Avatar
Russian Pimp
I want the diffuser!!!!!!!!!
Old Jan 15, 2007 | 12:14 PM
wawawooo weeee a nother chicago guy.... where did this come from and happen...
Old Jan 15, 2007 | 12:16 PM
emo236's Avatar
confuzed member
vova, you could make that pretty easily.
Old Jan 15, 2007 | 05:11 PM
v0va's Avatar
Russian Pimp
I would, but I wanna know what real benefit it has? I would be scraping that thing all around the place.
Old Jan 15, 2007 | 05:17 PM
emo236's Avatar
confuzed member
no real benefit unless you're hitting high speeds.
Old Jan 16, 2007 | 07:52 AM
bardabe's Avatar
Bad Speller
really really high speed on high winds on a really light vehicle. point is street cars don;t need it. how often do oyu go 160+ mph??? if u do it often then by all means get one.
Old Jan 16, 2007 | 10:01 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
It should not do anything on a truly healthy car. The purpose of the balance tube is to balance out airflow between the left and right banks. There should NOT be a big enough difference between airflow to warrant the need for a larger or extra balance tube; the differences in airflow should be minimal. If there is a huge difference in airflow that would make the extra balance tube (or larger balance tube) necessary, then there's a problem with the car that needs to be worked out properly.
richZTT
Jun 28, 2009 05:26 PM
duowing
Sep 4, 2008 01:56 PM
Z32GhOSt
Aug 20, 2008 01:45 PM
Shameless
Apr 14, 2006 06:25 PM
zguy36
Feb 1, 2002 11:15 PM
