ZDriver.com
-   300ZX (Z32) Forums (https://www.zdriver.com/forums/300zx-z32-forums-7/)
-   -   bad oil pump??? (https://www.zdriver.com/forums/300zx-z32-forums-7/bad-oil-pump-21644/)
murrayc83 Jan 29, 2007 06:09 AM
bad oil pump???
Anybody ever hear of oil pump issues with 300's?? I have a '92 TT with 74 k miles on it...This past weekend the oil pressure started dropping real low (10psi) after it warmed up when I was at idle. While driving it seemed pretty normal, however (~ 60 psi). Pretty sure the sending unit works bc I tested it and the resistance seems within the range in the book. Oil level was fine too. Any input??
CanyonCarver Jan 29, 2007 09:01 AM
I would try an aftermarket oil pressure gage first, before assuming the pump is going bad.
91zxtt Jan 30, 2007 08:40 PM
It's pretty common with these cars. It's probably your oil pressure sending unit.
snwbrderphat540 Jan 30, 2007 09:02 PM
hmmm.... yeah...
ummm..... sorta a DUH question but you frequently change your oil and oil filter? jsut so your not getting any blockage.... you know?
91zxtt Jan 30, 2007 09:08 PM
99.99% likely that it's the sending unit. .01% that it's a blockage.
snwbrderphat540 Jan 30, 2007 09:16 PM
really... just .01???? haha.... thats an interesting statistic.....
91zxtt Jan 30, 2007 09:21 PM
Sorry, maybe like .001%.
murrayc83 Feb 1, 2007 05:27 AM
Just a follow up...I took out the sending unit and sprayed down the elec. components, even though they didn't look damaged or corroded. Seems to be working now. Kind of a relief too...I had a quote for 14 hours of labor if it was the oil pump!!
snwbrderphat540 Feb 1, 2007 09:22 AM
14 hours!!!! ouch......multiply that by an 80 dollar and hour shop rate......
naviathan Feb 1, 2007 10:32 AM
That's rediculous. If it takes them 14 hours to do an oil pump on a L6 they need better mechanics.
snwbrderphat540 Feb 1, 2007 12:18 PM
Z32... vg30dett not L6... still should take 14 hours i wouldnt think...
naviathan Feb 1, 2007 12:22 PM
Oh shite, I hit the new posts and thought I was still under the 280 forum...lol Oops...
