Automatic Transmission slipping only at highway speed
1993 NA 2+2 with a RE4R01A. (newbie at trouble shooting automatic transmission)
I have a automatic that is slipping only in 3 rd gear at highway speed, only when I punch the gas peddle. Driving less then 45 mph and then punching the gas peddle, not letting the transmission to down shift to second gear, three gear is not slipping. I connected a transmission pressure gauge today. Idle Specification is 60-71 PSI, I'm reading 50 PSI. Stall specification is 148-159 PSI, I reading 165 PSI. During my test drives I'm reading the same PSI when third gear is hookup, not slipping, and when third gear slipping, about 165 PSI. So the numbers suggest the transmission pump is maintaining a good working pressure, no pressure drop-outs in any gear circuit, slipping or not. Any comments are welcome!
Thanks
Thanks
Fsm
Xenon doesn't currently have a factory service manual download for the 93, but it does have the 94, most likely pretty much the same.
XenonZ32.com Reference
In the PDF "AT", it covers the process above in my last post.
I purchased the car about a year ago (110K miles) and the previous owner had the trans rebuilt about 30K mile ago. I knew the trans had an issue when I test drove the care so I thought maybe with so low of mileage on the trans the problem might be with the valve body or the one of the solenoid valves sticking or going bad. I drop the valve body when through all the spools/valve and performed a 25 PSI test to the electric solenoid and nothing was found. After all this (oil was changed / with filter) others suggested I perform a trans pressure test to see if the pump was good or if there was a leak in one of the hydraulic circuits (third gear) before taking the trans apart for rebuilding. Nothing was found during the pressure test other then maybe the clutch plate are toast.
Hi ya i recently bought a 92 zx a/t and it started giving me problems on the transmission i switch the trany fluid n the filter n still giving me the not shifting issue, so i took it to a mechanic n he said that is not throwing enough pressure to shift, what is that i have to fix, any help is appreciated thx.
OK, what would I do? Get the Factory Service Manuel (FSM) perform the trans computer check first and if that check "good" then move onto performing the electrical test, checking the solenoid valves resistance. The connector is located right next to the power steering reservoir. Don't forget to check the "Dropping Resistor" which is a "Current Shunt" for the Pressure solenoid located on the the passenger side inside or under the wheel well fender.
Good luck!
skywalker
Jun 8, 2014 06:57 PM
personalbox
Feb 18, 2002 07:33 PM
