Australian Z32
Old May 17, 2006 | 03:54 AM
Velox ZX's Avatar
From: I'm located in the more southern local... Jackson, MS.
Australian Z32
"Standard block, rebored 020, plate honed, o ringed, deburred, internal polishing, decked & line bored
cylinder heads-ported, triple cut valve seats,nismo hydraulic lifters, custom wade cams (my specs). Nismo vernier intake gears and custom vernier exhaust gears.O ring receiver groves
Con rods- billet Eagle H beams, x rayed, crack tested,
ARP Bolts
Pistons- Custom JE with Hastings rings,8.0/1 comp
deburred
Crankshaft- Billet Sainty built with rolled radius, Knife edged and nitrided, balanced, crack tested
Main girdle, Billet steel machined 2" thick to outside of block, studded main caps and thru bolted to pan rail on block.
Custom intake manifold with 6 50mm throttle bodies, Custom intake plenum with ram tubes
Custom exhaust manifolds
Twin Garrett GT35r turbochargers with modified exhaust housings
Custom alloy intercooler plumbing
Custom GTR spec intercooler
Custom 3" dump pipes to twin 3" exhaust
Custom 4" alloy air intake & remote filter
Custom alloy vacuum tank for brakes & clutch
Custom alloy breather can
Earls braided hose throughout
ACL main & big end bearings
Copper head gaskets
Custom stainless swirl pot
Twin Bosch motorsport pumps,Twin 5/16 fuel lines, Malpassi regulator, 7/16 return line
6x 720cc injectors
NIsmo flywheel
OS Giken twin plate clutch
Single piece tailshaft
Custom copper, reverse flow radiator
Autronic SM2 with 6 coils running full sequential injection,
Antilag & rotational idle.
Hell, even the oil filler cap was custom made!!
Custom baffled alloy sump
Unique Autosports front bar with side speed holes for oil coolers."
OH, and btw... it's acclaimed at 900hp.. ? From a site called UniqueAutosports.com I figured if I was stupified by the "surge tank" manifold.. you guys would be too.
Old May 17, 2006 | 08:45 AM
b300z's Avatar
caught the z fever
hmm. id like a ride
Old May 17, 2006 | 09:37 AM
silvrhand's Avatar
Snazzy Title
Yah that car has been around for a few years there was talk about it for a while due to the custom intake, it doesn't seem like it would be very effecient to pipe your intake to one side like that.
Old May 17, 2006 | 08:02 PM
WhtFairLadyZ's Avatar
I just love how clean it is....everything is SOOO perfect. Excellent Z!
Old May 17, 2006 | 10:19 PM
Riz Z Speed's Avatar
Administrative Brown Guy
yeah seen that one before. It's turbo'd? someone showed me that and said it was supercharged.
Old May 20, 2006 | 11:35 PM
Comorat2x2's Avatar
Looks like a super charger to me.......*shrug*
Tsuka89
Oct 16, 2012 07:46 PM
Spudz
Australia
Oct 25, 2002 08:20 AM
kolts
Jul 30, 2002 07:27 PM
mck2
Jun 6, 2002 07:35 PM
