After removing the door panel…
Old Jan 7, 2010 | 06:41 AM
filter_sweep's Avatar
So the nylon/plastic driver’s side door lock actuator in my ’90 2+2 has become stripped and no longer works. I confirmed this by removing the door panel and shining a flashlight behind the inner metal panel and I can see the door lock turns nicely but the actuator has become disconnected. I ordered a replacement actuator, but now I’m stuck on how to get to it to install it.
After I remove the door panel (like to do a speaker swap), how do I get behind the inner metal panel that covers the window and door lock mechanism? Will I screw anything up (like my power window) by removing it? It seems to be welded to the exterior door, but maybe that’s just paint?
Thanks in advance for any help. I’ve spent a couple hours searching the web and the online service manual but can’t find the answer to a seemingly simple question.
Old Jan 7, 2010 | 07:41 AM
solarwater's Avatar
I pulled my door lock the other day to get a broken key out of it, and I followed this guide.
http://www.ttzd.com/tech/doorhandletech.html
It took a little while to figure out how to line it all back up right when I put it back together, but it worked.
Old Jan 22, 2010 | 01:18 AM
Scrap-Iron's Avatar
Take a very long and thin screwdriver, or a piece of harder type wire. It is very fiddling but it will work, it takes a time to put the pieces back in place I had same problems when I put my boards back in place
stiletto660
Jan 24, 2012 01:52 PM
rogerz
Sep 28, 2011 11:27 AM
my86z
Apr 13, 2008 03:54 PM
rupert42
Mar 26, 2004 08:44 PM
Core
Nov 20, 2001 05:19 AM
