1993 300zx fuel cut off switch ?
Old Oct 12, 2007 | 10:07 PM
nismo619's Avatar
Hello does any one know if the 1993 nissan 300zx has a fuel pump cut off switch ? if so were is it ?
Old Oct 14, 2007 | 07:21 PM
nickz31's Avatar
i dont know one, but it would be easy to make
Old Oct 17, 2007 | 05:43 AM
Comorat2x2's Avatar
I THINK the factory security system has one tied into it but I have no idea where it would be. Best I could tell ya would be somewhere between teh gas tank and the engine
Old Oct 17, 2007 | 02:52 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
The 300ZX doesn't have a factory fuel cutoff switch. Many Z owners install one though.
If you're having fuel delivery problems, tell us what the problem is and we'll help diagnose it. If you're not getting fuel, I'd suspect it's a faulty fuel pump control unit (which is a common problem).
Old Nov 7, 2007 | 03:20 PM
Nemo1080's Avatar
2nd. does not exist.
Old Nov 10, 2007 | 02:20 AM
napoleonzheking's Avatar
F5 Hero
make sure the relay is plugged in good (green relay behind the driver side kick panel. have to remove some screws and it's kinda a bitch bc the hood release cable and lever, but you don't have to take it all the way off if you have small hands). one time mine came unplugged some how...
easiest way to see if your having fuel delivery problems, get a bucket, take the hose going into your fuel filter off, point hose into bucket, turn key. see if fuel pumps out.
Old May 10, 2012 | 07:04 PM
k3j300zx4lyfe's Avatar
im having fuel delivery problem on 1990 NA 2+2, my z cranks but doesnt start, so i figured the fuel pump is bad, after running some test i found that the pump works, but it doesnt work when i connect it to the connector, the connector has power, i checked the relays and fuses. so i thought maybe its the cut off switch?? can you help??
Old May 14, 2012 | 07:21 PM
jverz's Avatar
The only fuel pump switch that I know of is in the ECU (pre OBDII and likely after). It can be turned off in active test with diagnostic tools like Nissan Datascan but that's not likely your problem.
Jason280ZX
Dec 26, 2013 11:37 AM
lukeh
Jan 8, 2011 01:48 PM
nismo619
Apr 7, 2010 02:35 PM
Mark H
Jan 17, 2010 09:37 PM
Z32FTMFW
Nov 11, 2009 11:58 AM
