1993 300zx fuel cut off switch ?
Subscribe
Oct 12, 2007 | 10:07 PM
Hello does any one know if the 1993 nissan 300zx has a fuel pump cut off switch ? if so were is it ?
Reply
Oct 14, 2007 | 07:21 PM
i dont know one, but it would be easy to make
Reply
Oct 17, 2007 | 05:43 AM
I THINK the factory security system has one tied into it but I have no idea where it would be. Best I could tell ya would be somewhere between teh gas tank and the engine
Reply
Oct 17, 2007 | 02:52 PM
The 300ZX doesn't have a factory fuel cutoff switch. Many Z owners install one though.
If you're having fuel delivery problems, tell us what the problem is and we'll help diagnose it. If you're not getting fuel, I'd suspect it's a faulty fuel pump control unit (which is a common problem).
Reply
Nov 7, 2007 | 03:20 PM
Quote: The 300ZX doesn't have a factory fuel cutoff switch. Many Z owners install one though.
2nd. does not exist.
Reply
Nov 10, 2007 | 02:20 AM
make sure the relay is plugged in good (green relay behind the driver side kick panel. have to remove some screws and it's kinda a bitch bc the hood release cable and lever, but you don't have to take it all the way off if you have small hands). one time mine came unplugged some how...
easiest way to see if your having fuel delivery problems, get a bucket, take the hose going into your fuel filter off, point hose into bucket, turn key. see if fuel pumps out.
Reply
May 10, 2012 | 07:04 PM
im having fuel delivery problem on 1990 NA 2+2, my z cranks but doesnt start, so i figured the fuel pump is bad, after running some test i found that the pump works, but it doesnt work when i connect it to the connector, the connector has power, i checked the relays and fuses. so i thought maybe its the cut off switch?? can you help??
Reply
May 14, 2012 | 07:21 PM
The only fuel pump switch that I know of is in the ECU (pre OBDII and likely after). It can be turned off in active test with diagnostic tools like Nissan Datascan but that's not likely your problem.
Reply
Subscribe
