Tire pressure
Old Aug 28, 2005 | 07:35 AM
nismo613's Avatar
Tire pressure
My sticker with the tire specs on it has been worn off since i got the car. How much pressure is supposed to go in the tires according to the sticker? Thanks.
Old Aug 28, 2005 | 09:40 AM
MarkieMark's Avatar
And the Funky Bunch...wtf?
do you have the orginal tires or aftermarket? doesn't it say on the tires? im not really sure because i have aftermarket tires on mine.
Old Aug 28, 2005 | 09:53 AM
nismo613's Avatar
I have aftermarket, they have a max psi, but i dont think i want to put in the max amount of pressure. I dont think that would be good.
Old Aug 28, 2005 | 10:18 AM
bardabe's Avatar
Bad Speller
mine said max PSi was 50 so I would go ahead and run teh car (tire pressure increases) then check and if required I'd put 45 PSi.
Old Aug 28, 2005 | 10:56 AM
Spyder Z 15's Avatar
I usually don't put in more than 40.
MarkieMark's Avatar
yea i do the same
Old Aug 28, 2005 | 05:09 PM
91zxtt's Avatar
45!?! You guys are crazy. I'm usually at 34-35 psi. 45 is way over inflated. It must be like driving on stones instead of rubber. You must go through tires as often as you change your socks.
Old Aug 28, 2005 | 06:41 PM
MarkieMark's Avatar
i got falken ziex tires and max psi in those is 50 but i put 45
Old Aug 28, 2005 | 07:08 PM
Riz Z Speed's Avatar
Administrative Brown Guy
i have an NA 2+2 so it might be different for yours.
My label says 32psi front, 36 rear for stock sized tires.
Old Aug 28, 2005 | 08:42 PM
b300z's Avatar
caught the z fever
i usually put no more than 40 in mine
Old Aug 28, 2005 | 09:33 PM
bardabe's Avatar
Bad Speller
Uhm in 6 months i had 3 new sets of tires. well 6 tires all for the back. U'll be amazed how badly you go through tires Drifting.
Old Aug 31, 2005 | 09:26 PM
91zxtt's Avatar
Rizz asked this question earlier....
When was it exactly that you became a dumbass?
Old Sep 1, 2005 | 04:28 PM
bardabe's Avatar
Bad Speller
I have no clue.
280zx_82bizox
27
Aug 10, 2009 10:43 AM
HDPD350Z
Jan 16, 2006 02:35 AM
Fast240Z
Jun 1, 2005 12:58 PM
tube80z
Apr 18, 2005 05:10 PM
