Strut Tower Bars installation
3 Attachment(s)
I recently purchased a set of strut tower bars (front & rear). I wanted in install them, but find that there are some spot welded brackets in the way in the front. What I wanted to know is what you guys did to get around this issue. Did you remove the spot welded brackets and relocate them, or did you grind reliefs in the mounting flange of the strut bar to clear these brackets? My vehicle is a '90 Z32 2+2 NA. Also, for those of you that have installed strut tower bars, how much of a difference did they make for you in the handling of the car?
Thanks! |
I would just grind them to clear the thing, and replace ny fuel lines.
More
which bars did you get?
Bars
BTW - I went to our local Z-Club meeting last night. There was a guy that had a front strut bar installed on his '93 convertible. I checked it out. He only ground off one bracket on the passanger side, bent the remaining brackets out of the way, did some grinding on those brakets where they attach to the body, and then mounted them on top of the braket flanges. He also had to grind a little of the top of the front ears of the strut mounts to clear the bottom of the hood, but did good. This is what I am going to do as well. I bought a side grinder and some wheels for it to help with the modifications to facilitate the strut bar installation. Thanks! |
i think i'd rather modify the bar than modify the car for the bar to fit.
The bars that your zclub member has, are they the same ones you got? |
Are there any bars that don't require mods? Some people speak highly of the
ca(r)bing bar. |
I think you mean "carbing" Those are awesome. Charles showed them to us at the club the other night. They also come with a hefty price tag. $300 each.
Maybe!
Originally Posted by CanyonCarver
Are there any bars that don't require mods? Some people speak highly of the cabing bar.
Remove the bracket on the passenger side the holds the AC line since it's not necessary and can be zip tied in alternate locations. Remove the bracket on the the drivers side since all it hold is the engine bay light switch. Install a washer over the passenger side strut stud that is closest to the power steering reservoir bracket. The washer should be about the same thickness as the PS bracket.
When it's all said and done, don't be surprised if it still doesn't fit. There aren't many front strut bars that fit right on these cars. Carbing is one of very few. |
Update!
3 Attachment(s)
I installed the front Strut Bar this past weekend. Thought that I would post some pics to show the installation. I cut and ground off the hose braket on the the passanger side. I bented the power steering pump bracket out of the way, and routed a slot in the bracket that holds the vacuum 'gizmo'. I re-routed the throttle cable, replaced the fuel lines and re-routed them slightly, and bent the bracket for the hood security switch. I also cleaned up the engine compartment, as you can tell from the previous pictures to the ones shown here.
Thanks for the help! (Once again) |
Looks really good. :)
2nd. I've had my eye on that bar for a while. looks really great, temptation growing. |
Go For It!
2nd.
I've had my eye on that bar for a while. looks really great, temptation growing. I have a new spoiler coming in today. Its an aftermarket version though exactly like the stock one. I have also ordered a Greddy urathane front body kit (front bumper only), a Bomex vented facial piece, and a carbon fiber hood! I can't wait to get it all installed and the car painted. I will probably install the rear strut bar this weekend. Should be easier than the front! :p |
painting the carbon fiber hood?
Nooooooooo!
