Skyline brake upgrade
Originally Posted by ztuner
3000GTVR4 kit - Upside - cheapest. Easy to find rotors and other parts, and gives you every benifit of a big brake kit. Downside - you need to use 15 mm spacers on the front wheels if you want to fit 16's. Fits 17's
Just for the record, the Skyline brake rotors are only 1.5 centimeters larger in diameter. Like Harry said, the thickness helps with fade and warping, but the kit won't stop much better than stock. That's why I like the 3000GT VR4 kit... sure, it needs 1.5cm wheel spacers, but that's a small sacrifice for 1.5 extra inches in diameter.
Originally Posted by tnkrstoyco
Check this link, it might be what you want to do.
http://s95014253.onlinehome.us/63104/104050.html
CC you know I didn't even think to compare the differences from the 350 to the 300, mine are sitting right next to each other.
one of his conditions is that the brakes must fit under the stock wheels... 350Z rotors do not.
I am not a kid and I am not fixated on the Skyline kit. I just wanted info on it. Like I said, I wanted a kit that looks stock and requires no modification. The Skyline kit provides that. Basically, I was curious whether anybody had actual numbers, not alternative solutions. I like to concentrate on one thing first. Then, when I have the info on that, I will move onto the other options. That is all that took place here.
CodeWarrior
Sep 15, 2005 06:09 AM
GodZilla
12
Jun 30, 2004 11:37 AM
. from what i am reading though, the 3kgt kit looks pretty good. maybe i'll get that when i find a z32.
