Noise from the rear axle
I am getting a noise from the rear axle on my '90 Z. It's difficult to describe it, but at low speeds it sounds a little like a bad wheel bearing.
I haven't checked the bearings yet but I will when the weather improves. Anyone have an idea what this could be, or had the same problem? Thanks for any help, JohannB |
Sounds like a wheel bearing to me
If it sounds like a wheel bearing....it probably is.
Are you sure it's in the axle and not the drive shaft. If it's coming from the driveshaft, it could be the main support bearing. If it is coming from the axle, then I agree with everyone else. Just wanted to provide another possibility.
Rear axle noise
I think it's from the axle... because the sound is approximately 1 cycle with each rotaion of the tires, rather than being several cycles per tire rotation if it were the drive shaft.
Thanks for your help, JohannB
Thanks for your help, JohannB GAH i'm having the same problem (i'm a new user, my names alex) and i thnk i ahve EVERY problem identified for the Z32 on this site... it's a shame... but slowly and surely i'm fixing them one by one... my realistic goal is to get this car runnning like brand new... i have the same squak....squeak... squeak.... in the rear axle... and then when you speed up it becomes a shrill high pitched shriek and then the engine and exhaust (full of holes) noise drowns it out... so it's a wheel bearing? thanks that'll speed up my search and destroy and replace |
Noise
The noise mine is making is not a squeal or squeak, but more of a knock like sound. I replaced the 2 rear tires and the car is a little smoother. Now I suspect the front tires may be the rest of the problem.
I have Goodyear Gators on the front and I have read that they tend to become noisy and rough riding over time. I am going to try replacing them with Bridgestones like I put on the rear and see what happens. The Bridgestones are excellent and stick like glue even on wet pavement. I was amazed at the traction I have in the wet. If you are hearing a squeaking noise, it could be wheel bearings, or even the wear indicator on the brake pads. It is designed to contact the rotor and make a high pitched squeal when the pads are near worn out. Johann
thanks a lot i know i have a lot of Brake issues to work out.. i'll fix those first and try and diagnose any other problems
Usually, when a wheel bearing is going bad, you will see some play, or losseness in the bearing. This can generally be checked by jacking the wheel off of the ground and grabbing the tire at the top and bottom and trying to tip it in and out. Any movement is bad. (you will more than likely feel this movement rather than see it). Also, as you rotate the tire with your hand, listen (feel) for any grinding.
I check my wheel bearings every 5k miles when I rotate my tires. |
