KasbeK's Shake and Brake Questions
Air drawn from underneath the car, past the rotors, out.
I would almost bet your rotors aren't the problem unless you drive like a dick. I have never had rotors warp on me... and it isn't common on the Z32 (brake fade is, warping isn't).
done. having tires changed and the front end aligned has never stopped the shaking. they were all balanced by a good shop. i've been told that since when i had the rotors turned, he only did the braking surface, and i still have rust and crap on the edges, then that may be the problem. doubtful in my eyes, but it's really the best thing i have to go with. btw, rotating the tires had no effect either. it shaked while braking with the old tires too.
Get new rotors, don't cut the old ones. Technically, Z32 rotors aren't supposed to be cut the normal way - they require an on-car lathe (which most shops don't have). That could be having an impact.
oh thanks. that's good to know. rotors are my next purchase of any size. i found a good looking set of 4 slotted rotors for $300. i know i know, buy cheap buy twice, but these seem to have a good rep.
interesting. i didn't expect performance gains to be too good, but at least present. at any rate, if the slots don't hurt anything, i think i'll go with this set, as the price is agreeable with me, and they come with pads and stainless steel lines.
lol shizzle. i just checked the page again and either i got the wrong number in my head or the price changed. it says $450 now... maybe not those.
http://www.czp.us/Cart/description.p...9163.251.239.3
these are the ones i'm thinking of. thanks for all the advise here btw.
here it is
my brake parts thread. what do we think of these rotors? i'm skeptical because the rears aren't vented. the stock ones are vented aren't they? i haven't seen them in a while. i've forgotten. anyway, i can get this set of 4 shipped for a total bill of right around $220-225. pretty good deal i think. i'm no brake expert, but it seems to me that downgrading to non-vented rears might cause some problems if any substancial braking ever occurs though. thoughts?
http://www.tirerack.com/brakes/resul...=&brand=Brembo
i'm looking at the ones at the top. i've been persuaded against any rotors with slots or cross-drills, so i'm not really up for spending that much money for the little bit of benefit on teh ones farther down the page.
Rears are originally vented - I wouldn't recommend getting non-vented at all, but rears do less than 30% of your stopping so it might not be a problem. Why are you even replacing the rears, though? I'd bet they're still fine and not the cause of any of your problems...
I say just go with the Brembo replacements...
http://splparts.com/main4/parts/Z32/...es/default.htm
Moved unrelated posts from Fairlady Pics thread ( https://www.zdriver.com/forums/300zx-z32-forums-7/finally-my-fairlady-pics-27623/ ) and "here it is" thread.
thanks for the merge and thanks for the link, but the problem with it is that i have a 1990 N/A. the OE rotors for the front that they list are the wrong size (so they say). but, i agree with the idea to not replace the rears. i'm surprised i didn't think of that to begin with (though, maybe i'm not considering the regularity of the flaws in my thought processes lately...). so i'll start with just the fronts and see what happens.
i have thought about that, and thanks for the suggestion (i believe you may have even said that before in a previous thread, so sorry for making you say it again). the problem there is that i guess i don't rightly know how to check them. will a visual inspection suffice? i've done that, and they look pretty good i guess. not all rotten or anything.
a bit that i forgot to mention: as said, i got the rotors all turned. after having the fronts turned, the shake was gone for about 2-3 stops. then it was back in full effect.... i was a bit puzzled. the guy that turned them suggested a light brake in of 2 60-30 decelerations with moderate effort, which i did, and they felt good. i don't know what to make of all that.
all things considered, as it stands, tention rods are on my list, but after front rotors. i need to do all the front end bushings actually. i just rotated the tires to find some pretty bad wear on the inside of the left one. the rears and right front were just perfect though. even after a few good doughnuts.... did i say that out loud...?
KasbeKZ, where are you in VA. Bernie is in the Alexandria area and he could quickly point you in the right direction. Also you should fill out your profile so that folks can help you more quickly. The early '90 NA z32, has thinner rotors that were prone to warping, that's why they were changed to the thicker rotor of the TT across the board. You should consider changing to the later calipers and rotors when you do your breaks.
that's a good idea. i'm a long way from alexandria. there is a decent guy way closer to me than that. are the 1990 rotors that are sold still thinner than they should be? because i do believe that these are very prone to warping. thicker calipers sound like a good idea.
Yes, the 1990 NA Z32 rotors are designed as stock replacements for the early 1990 rotors. If you want to get the thicker rotors you'll need to replace the rotors and calipers with the units designed for the TT and later model year NAs.
