Best tires for the Z
Subscribe
Jan 23, 2004 | 12:48 AM
Excellent info...thanks Rizz. Do you have any personal experience or second hand experience with S-03 ploes position's? I imagine some major grip. I have the pzeros and I'm very happy with them. That info really helps alot...thakns again.
Reply
Jan 23, 2004 | 12:52 AM
sorry, no.
Only tires I've had on my Z are the original worn out Michelins that were on it(obviously bad), Cooper Cobras(ok, wear fast), BF Goodrich kdws(good wet grip, decent wear), and the Kumho Ecstas(decent grip, dk on wear yet).
Reply
Jan 23, 2004 | 01:01 AM
What would you say is a step up from the ecstas? A good tire that is just a bit better and only a bit more expensive than the kumhos?
Reply
Jan 23, 2004 | 01:18 AM
Best bang for the buck? You decide.
http://www.tirerack.com/tires/tires....h=true&index=6
If you like anything you see from the Tire Rack, remember I have an account with them. If you'd like to save a few bucks, you can order anything that they stock from me.
Help out a brother out and throw some money my way.
Reply
Jan 23, 2004 | 01:24 AM
That tire isn't available in a Z rated tire, is it? Actually, I don't really know what that whole Z rated stuff is all about...what is ti all about? How important is it to have a Z rated tire? This is good...don't know much about tires as you can see.
Reply
Jan 23, 2004 | 01:25 AM
Oh and when I get new tires...definitely by the end of this summer I'm sure....I'll look your way.
Reply
Jan 23, 2004 | 03:13 PM
Speed ratings
My good friends the Tire Rack had this to say:
Speed Rating
In Europe, where selected highways do not have speed limits and high speed driving is permitted, speed ratings were established to match the speed capability of tires with the top speed capability of the vehicles to which they are applied. Speed ratings are established in kilometers per hour and subsequently converted to miles per hour (which explains why speed ratings appear established at "unusual" mile per hour increments). Despite the tire manufacturer's ability to manufacturer tires capable of high speeds, none of them recommend the use of their products in excess of legal speed limits.
Speed ratings are based on laboratory tests where the tire is pressed against a large diameter metal drum to reflect its appropriate load, and run at ever increasing speeds (in 6.2 mph steps in 10 minute increments) until the tire's required speed has been met.
It is important to note that speed ratings only apply to tires that have not been damaged, altered, under-inflated or overloaded. Additionally, most tire manufacturers maintain that a tire that has been cut or punctured no longer retains the tire manufacturer's original speed rating, even after being repaired because the tire manufacturer can't control the quality of the repair.
Over the years, tire speed rating symbols have been marked on tires in any of three ways shown in the following examples:
225/50SR16 225/50SR16 89S or 225/50R16 89S
Each of these was an acceptable method of identifying speed ratings.
Early tires had their speed rating symbol shown "within" the tire size, such as 225/50SR16. Tires using this type of branding were not to have been produced after 1991.
225/50SR16 112 mph, 180 km/h
225/50HR16 130, 210 km/h
225/50VR16 in excess of 130 mph, 210 km/h
Beginning in 1991, the speed symbol denoting a fixed maximum speed capability of new tires must be shown only in the speed rating portion of the tire's service description, such as 225/50R16 89S. The most common tire speed rating symbols, maximum speeds and typical applications are shown below:
N 87 mph 140 km/h Temporary Spare Tires
P 93 mph 150 km/h
Q 99 mph 160 km/h Studless & Studdable Winter Tires
R 106 mph 170 km/h H.D. Light Truck Tires
S 112 mph 180 km/h Family Sedans & Vans
T 118 mph 190 km/h Family Sedans & Vans
U 124 mph 200 km/h
H 130 mph 210 km/h Sport Sedans & Coupes
V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars
When Z-speed rated tires were first introduced, they were thought to reflect the highest tire speed rating that would ever be required, in excess of 240 km/h or 149 mph. While Z-speed rated tires are capable of speeds in excess of 149 mph, how far above 149 mph was not identified. That ultimately caused the automotive industry to add W- and Y-speed ratings to identify the tires that meet the needs of new vehicles that have extremely high top-speed capabilities.
W 168 mph 270 km/h Exotic Sports Cars
Y 186 mph 300 km/h Exotic Sports Cars
While a Z-speed rating still often appears in the tire size designation of these tires, such as 225/50ZR16 91W, the Z in the size signifies a maximum speed capability in excess of 149 mph, 240 km/h; the W in the service description indicates the tire's 168 mph, 270 km/h maximum speed.
225/50ZR16 in excess of 149 mph, 240 km/h
205/45ZR17 88W 168 mph, 270 km/h
285/35ZR19 99Y 186 mph, 300 km/h
Most recently, when the Y-speed rating indicated in a service description is enclosed in parenthesis, such as 285/35ZR19 (99Y), the top speed of the tire has been tested in excess of 186 mph, 300 km/h indicated by the service description as shown below:
285/35ZR19 (99Y) in excess of 186 mph, 300 km/h
As vehicles have increased their top speeds into Autobahn-only ranges, the tire speed ratings have evolved to better identify the tires capability, allowing drivers to match the speed of their tires with the top speed of their vehicle.
Reply
Jan 23, 2004 | 05:27 PM
WOW! Great info. Rizz...once again...exactly what I needed to know. *applause* So basically, the W rated tires are better than any Z rated tire? One more question. Take a look at this:
http://www.tirerack.com/tires/Sizes....odel=AVS+ES100
What are speed ratings of WR or VR, etc indicating? Is that a speed rating of W, V, or R. IT's in the formation that the info you gave me says they used to do it(early years) and not after the tire size (i.e., 205/45ZR17 88W). Thanks Rizz.
Reply
Jan 23, 2004 | 08:00 PM
rizz i am gonna need some 225-40-17 and some 245-40-17 pretty soon, they go on my 17'' motegi's which are soon to be my winter tires since i am getting those ADR's for Valentines day yeah baby
Reply
Jan 24, 2004 | 10:43 AM
Uhm...not quite Emo. W and Y rated tires are Z rated, except that they are subcatagories of the Z rating, with the Y's having a higher speed rating than the W's. But unless you are planning to drive your Z up to 168mph or *Holy Mackerel*186mph, you will not really need W or Y rated tires respectively.
Your second question asks what the speed ratings are for the WR and the VR. The WR and the VR indicates the W-rating and V-rating respectively (well...as read on the tire, it tells you rating and rim diameter), so the former has been tested safe for travel up to 168mph while the latter for up to 149mph. Don't let the R throw you off...
My slow@$$ Z31 only goes up to around 140 (I've only actually gone up to 125 at ~5000rpm on 5th), so I'll only really need V rated tires at most. If I plan on driving like my grandma, then even the S rated tires should be more than enough. Currently, I have H rated tires and they're sufficient for my travel/racing needs.
Reply
Jan 24, 2004 | 11:07 AM
Cool...good deal. So, basically, I'll probably want some Z rated-Y tires! 186 here I come!!!
Reply
Jan 24, 2004 | 08:47 PM
i get my license back in two weeks...as much as i wanna drive fast and crazy, i won't be able to unless its a back road. so i don't need a 186mph tire, not that my n/a can go up there....the fastest i've gone in it was 150mph at about 6,000rpm...talk about a rush....my passenger closed her eyes, and held on the the bar on the door...also called as the "oh sh*t bar" fun times in a Z
Reply
Jan 24, 2004 | 08:56 PM
Yea...that's the fastest I've gone as well. Don't know if I'd ever do it with someone else in the car..but whatever. The Z feels comfortable up there. It wanted to go faster...but I didn't! On long trips...I have a hard time keeping it under 100...it seems to just wanna go there....even when I'm just trying to hold her at a steady speed...give her just a little more and she starts climbing.
Reply
Jan 24, 2004 | 09:00 PM
i just love the way this cars feels over a 100...god it feels good, it feels like it comes to life, it's an amazing machine
Reply
Jan 24, 2004 | 09:25 PM
2nd.
Reply
Jan 25, 2004 | 12:48 PM
Thanks, Copper for answering those questions. I've been busy this weekend helping my cousin move.
Z-Wrecker, I got ya covered. I sent you a pm.
Anybody else want/need tires?
Reply
Jan 25, 2004 | 08:51 PM
got it rizz...i'll measure the rims again, and then we'll see from there
Reply
Subscribe
