anyone have 9" wide rims in the fronts
Does anyone have 9 inch wide rims in the front. I want to know what size tires you have on there. i heard from volk racing that if i put a 245/40/18 i will have a slight rubbing. Instead they directed me to put a 235/40/18 on. I am putting on the volk racing SF CHALLENGE wheel with a 34 offset with toyo proxies T1Rs if that information make any difference.Anyone have this done or experienced this??
Thanks |
9" is too wide for 245's.
I have 255's on 8.5" wheels in the front. No rubbing. |
245's on 8.5's in the front. it's a tight squeeze, no rubbing though
so will i be fine with 235/40/18 on the fronts? I HAVE THE RIMS THEY LOOK AMAZING.. what size tire should i put on? what do u suggest?
The main issues I had was see'ing if they would fit and what not. Use this calculator to see what will help fit. If your car isn't lowered and u have stock suspension, that will fit easy.
http://gs.tolan-hoechst.com/tirecalc.htm |
I am running the Enkei RPO-1 18x9.5 in front and rear. My front tires are 255/35-18. Zero rubbing and it's lowered. The 245/40 may be too tall? 235/40 is definitely small.
If you have 9" wheels then 235's are waaaaaaaaaaaay too narrow. They'll look funny. |
What do you think? if i go 245/40/18 then i have a OD of 25.6 and a sidewall of 9.6mm WHAT SHOULD I DO HERE |
And what do i do about the rears? Go with 275/35/18? or wider?
So what do you suggest? I mean i could go with the 255/35/18. the OD would be 25.0in and the Side wall would be 10.1 mm .
What do you think? if i go 245/40/18 then i have a OD of 25.6 and a sidewall of 9.6mm WHAT SHOULD I DO HERE Your 255/35 tire will have a siewall height of 44.625mm. Your 245/40 tire will have a sidewall heigth of 49mm. |
What size rim do you have in the rear? I have a 10" rim back there. I think 275/35/18 will be good on the rear. As for the fronts, im thinking about the 255/35/18 from everyone here.
I have 9.5" in the rear, and 9.5" in front.
I have 285/30 18s in the rear on 9.5s and they fit perfect with the 1" drop she has =0)
Do you have a side shot so we can see how much the tire sticks out from the body panel? If it sticks out at all. The 285's are what I want to move up to next, but the last time I had one put on my wheel (about 4 years ago) it stuck out like a boy racer car.
it all depends on the wheel offset thou. If you have 285 on the rears with a good offset it should be fine ? Right?
I had already mentioned this in a prior post, and I think when I had those tires put on my car for a test fit I had stock camber settings. They stuck out. Now, I have a better camber setting and my 275's actually are tucked inside the wheel well enough that a 285 tire should work okay. Next year, when I replace my rear tires I will have some test fit.
