18's on my Z32
Old Jan 20, 2012 | 08:24 AM
BrownBomberZ's Avatar
18's on my Z32
Ok so I found a set of wheels I like in the 18'' size they are 18x8.5 with +32 offset in the front and 18x9.5 with +35 offset in the rear. I have a 1990 2+2 and was wondering if these will work, I have found plenty of pages and what not telling me how to do the math to figure out what offset I need but I don't think I am doing it right. Does amyone know if the sizes I found above will work correctly for my Z?
Old Jan 20, 2012 | 10:03 AM
Rupe's Avatar
Horsepower Mathematician
When I bought my TT it already had stock rear wheels (16 x 8.5 w/ 35mm offset) all around + 1cm spacers all around. When I found the spacers, I took them off. This means those front wheels you found will fit for sure since the offset is somewhere in between what I had with and without spacers.
For the back ones, since they have the same offset as stock and are 1" wider overall, will stick out .5" on either side of your stock rear wheels. I'm quite sure this will fit without a problem, but now you have some kind of measurement at least to go in there and check for clearance as best you can.
Old Jan 20, 2012 | 11:59 AM
Thanks rupe for the info
Old Jan 20, 2012 | 01:30 PM
Rupe's Avatar
No problemo. What wheels did you find? Are your roads good? I don't think I could get away with 18's where I live.
Old Jan 20, 2012 | 03:24 PM
Found some cheap stern wheels on eBay... The roads are ok in my part of Florida I think I will be ok with these wheels for now....just have to find the right size tires for these wheels now
Old Jan 31, 2012 | 07:50 AM
Bama1993zx's Avatar
I have 19x8 front and 19x10 rear TSW wheels with 225's up front and 265's in the rear on my 1993 zx
Old Jan 31, 2012 | 08:46 AM
Rupe's Avatar
What offsets are your wheels?
Old May 9, 2012 | 11:20 AM
ztommyx's Avatar
the wheels you mention should work just fine.
i've had 19x10 +25 on all 4 on my TT and it was fine w/o any issues.
Old Jan 14, 2014 | 04:04 AM
SpecialK47150's Avatar
Any pics of the wheels on the car?
