Taillights
Old Apr 16, 2009 | 10:08 PM
96z32(racer)'s Avatar
Taillights
Hey how easy is it to take out the whole set of the stock taillights. i just ordered the JDM taillights and was just curious how much work it owuld be to take the stocks out. thanks for your help
Old Apr 16, 2009 | 10:53 PM
KasbeKZ's Avatar
Pr0n Addict
you just take the trim out of the trunk, find the bolts to the lights, and you have to heat the epoxy that holds the middle one i think. says the write up that i read. i haven't done it though.
Old Apr 16, 2009 | 11:18 PM
ok thanks tomorrow if i get the tailllights ill take a look at it. doesnt sound to difficult then besides the heating of the epoxy but sure can figure it out thanks alot
Old Apr 16, 2009 | 11:39 PM
napoleonzheking's Avatar
F5 Hero
blow dryer or 20 bucks for a heat gun from your local home depot for one that gets to like 2000 degrees. Usually it's so old and stuff though that you can pull them off... Also, IIRC there is a rubber gasket of some sort in there, but it might just be the epoxy goop. Check when you pull your old ones off.
Old Apr 18, 2009 | 11:43 AM
thank you napoleonzheking. i just did the taillights it was pretty simple and thanks for the tips on what needs to be done. ill post pics up tomorrow or so
Old Apr 21, 2009 | 03:43 PM
Darkmann's Avatar
Where can I get the JDM tail lights? They look so much better than OEM.
Old Apr 21, 2009 | 04:01 PM
KasbeKZ's Avatar
Pr0n Addict
well, you can make them, or get them from coz, or there are a couple other vendors that have them, bu CZP is the only one that i know of right now.
Old Apr 21, 2009 | 09:15 PM
i got mine from z1motorsports
Old Apr 23, 2009 | 11:59 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
Don't buy from Coz... he needs to learn his lesson via decreased sales for a while.
Any dealership can get them, Ultimate Z stocks them, Z1 stocks them.
And please don't make them... they turn out like **** 100% of the time. If I weren't able to tell the difference between real JSpec and homemade, I'd say go for it... but it's always so obvious. They forget the lines or make lines that are too thick or improperly spaced, they don't chrome the inner housings, they use the wrong pattern on the lens, etc etc etc.
Old Apr 24, 2009 | 07:25 AM
yeah even tho its little money i think its definately worth buying the JDMs and installing them than making it homemade. it is really noticeable from pics ivve seen and even people who have done it here. no bueno.
dviper3912
Mar 24, 2006 05:51 PM
duowing
Jan 22, 2006 01:33 PM
Mooney
Jun 18, 2005 08:22 PM
juggalo280ZX
May 29, 2005 01:43 PM
Skaitan
May 28, 2001 05:05 PM
