Sparco??
Old Jun 6, 2004 | 03:40 PM
1SIKZ's Avatar
Sparco??
what kind of adjustments or modifications do i have to do to install a sparco steering wheel & a set of racing seats what has to be done to have an operational 4 point harness??
Old Jun 15, 2004 | 06:23 PM
Riz Z Speed's Avatar
Administrative Brown Guy
to install the seats you'll probably have to buy some mounting brackets from Sparco. The steering wheel will most likely need a hub adapter. If your car is pre-92 w/o the airbags cool, if not i would recommend you keep the airbag for safety. Safety first.
As for the 4 point harness, it'll be easier to do in a coupe than a 2+2. You already have three points down via the oem seat belt. The fourth one will be a bit trickier as you'll have to mount it to the body somewhere behind you. You might have to do some searching and dissassembly to locate a proper mounting point.
Old Jun 15, 2004 | 07:05 PM
1SIKZ's Avatar
thanks guy u the man
scoobydoo512
Oct 22, 2010 09:58 AM
Zil32
FS: 300ZX (90-96)
Mar 14, 2006 02:43 PM
