Mismatched turn signals...
Old Apr 9, 2004 | 06:34 PM
Copper727's Avatar
Gold Member
Hello,
I just realized that my left turn signal blinks at a much faster rate than my right turn signal! All the bulbs appear to be working fine. What do you think might be the problem and how can I remedy this situation?? Thanks.
Old Apr 12, 2004 | 11:10 AM
91zxtt's Avatar
Take out each bulb and compare them side by side. One may be different than all of the others; which could cause the blinking speed to be different. All of the turn signal bulbs should be the same.
Old Apr 13, 2004 | 09:32 AM
tnkrstoyco's Avatar
Loves Going Topless
My 93' vert did the same thing, only with the lights on. worked fine with the lights off. Pulled the left side checked it out and put the same bulb back in and worked fine, that's been a year ago and still fine. Figured it was a ground or something. Acted like a bulb was out in the circuit which usually makes the good one flash fast.
Pez
Sep 19, 2014 04:54 PM
vJimmyv
Jan 21, 2013 02:17 PM
Tsuka89
Sep 14, 2012 12:49 PM
300zgearhead
Oct 9, 2011 11:48 PM
