Map Light Trouble
Old Sep 6, 2007 | 01:20 PM
Brettallica's Avatar
Map Light Trouble
I have this weird buzzing noise coming out of my map light assembly. I just called Courtesy Nissan and this guy, Steve, was super helpful. He was able to tell me exactly what the problem is; it's the "in-car sensor" (part number 27054MA). The problem is the replacement part is like $40 -- and it's this tiny little thing that I know I could find for less if only I knew where to look.
Any ideas?
Here are a couple pics (I broke it down progressively so you could get an idea exactly where the part is):
Old Sep 6, 2007 | 01:43 PM
entropy31's Avatar
The Cake Is A Lie!
it's a little fan thingy behind those two vents. it samples cabin air to provide feedback to the auto climate control. check junk yards.
Old Sep 6, 2007 | 01:52 PM
Yes, I know it's the fan. I opened the thing up before I called the guy and tried blowing it out with compressed air. That didn't really do the trick (read: it hardly did anything).
The crappy thing is I live in an area where there are pretty much no junkyards around. I found a used one on eBay, but who knows whether it has the same problem as mine.
Old Sep 6, 2007 | 02:22 PM
Goofyz's Avatar
so
how good are you with a soldering iron?
I am pretty sure you can either replace it with a very small fan you can get at a electronics supply store or just turn the radio up.
Old Sep 6, 2007 | 02:43 PM
Funny! Unfortunately I'm only running an old-skool Sony CD player head unit with no external amplification and probably the stock Bose speakers, so turning up the stereo is not a realistic option -- to say nothing of a permanent solution.
Now, the replacement fan idea might be something worth checking out. I am a mean solderer.
Old Sep 9, 2007 | 10:04 AM
MikeZ's Avatar
Yeah, I was ghetto and just jammed a piece of duct tape in there lol
Old Sep 14, 2007 | 11:01 AM
icanznow's Avatar
It happened to me, go here to fix it!
http://www.twinturbo.net/net/viewmsg...&msg_id=153888
"Carefully pop the entire vented plastic thing out & disconnect the plug. put a bit of oil at the bottom & top of the spindle in the fan. You may have to very slightly tighten the screw holding the fan but if you tighten it too much the fan won't work. Test it by turning the key on & see if the fan turns. Mine has been squeek free ever since. Was totally obnoxious!!! Hope that helps."
They have a fix on TT.net to this, I just can't find it because of our firewall here at work.
Hope it helps.
Todd
www.thecarspace.com/icanznow
Old Sep 14, 2007 | 11:33 AM
entropy31's Avatar
The Cake Is A Lie!
Hope it helps.
Todd
yay, another Wachington z32 driver. and just down the road from bleach and I
Old Sep 18, 2007 | 08:52 AM
Hope it helps.
Todd
Awesome! Thanks, bro! I'm gonna try this out and let you know how it works.
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
Turbo86
Jan 15, 2007 03:45 PM
DominicBox
Sep 9, 2004 08:41 AM
zbest91tt
Oct 26, 2002 03:36 AM
