I need hel pwith the wiring for these white glow gauges
Old Jul 26, 2005 | 05:51 AM
gentlejax2's Avatar
need to know what wires I need to hook up this inverter to for these dash gauges.
Old Jul 26, 2005 | 08:24 AM
Riz Z Speed's Avatar
Administrative Brown Guy
switched +12v and ground.
the bulbs that light up the dash is a good start.
there's plenty there to choose from so just be sure that you don't connect to a constant source or else your new gauges will have a much shorter life span.
Old Jul 26, 2005 | 08:59 AM
Denver93TT's Avatar
Sorry to cramp your style rizz but STOP RIGHT THERE. The inverters that come with these kits usually have there own dimmers. Read the directions carefully. If you connect these to a light on the dash you could short out the converter because your dash lights have a dimmer. It is very easy to open up the light switch panel and take the running light lead as your power for the lights. You can remove most of the bulbs on the back of the cluster but certain ones (it's been a while) need to remain to backlight the boost, oil press, and a couple of others.
Old Jul 26, 2005 | 09:01 AM
yeah you're right.
I shoulda thought of that.
I was just thinking about the one that i have. It doesn't have a dimmer, just on or off.
chicopriest
18
Aug 7, 2006 10:47 PM
DynamicJ
May 2, 2005 03:26 PM
waterdogzx
Jul 29, 2003 07:31 AM
speedgato2
Apr 8, 2003 09:46 PM
crazedwigga
Aug 22, 2002 11:56 AM
