HIDs
Ok. I got my headlamps and everything looks good except for one complaint. The driver's side projector looks positioned slightly different than the passenger. Also there is a screw sticking out if you look down in there. I emailed them about it and they said that they can fix the screw issue but that reopening the headlamp may cause problems down the road. Should I send it back or just install it and forget about it? They said that they mounted the projectors to the stock brackets and that it's unlikely that the screw caused the projector to shift. Here are the pics.
You can see the exposed screw on the bottom right side of the lens.
Drivers side:
You can see the screw on the passenger side as well but it's tucked underneath the plastic part.
Passenger:
There shouldn't be a problem with the light pattern as the aiming is done externally but it's just one of those little things that bug you.
Drivers side:
Passenger:
Originally Posted by Z_WRECKER
Wow, that is such a drastic improvement over stock, I'll most def do this mod on my next Z...STI has adjustable HIDs factory
.It does get good mileage. That's the only thing I like about it.
ummmmm....where is your intake?
Dude,...you're killin' me. Just about the time I think I'm approaching completion of the 'reasonable' mod list you go and do something like this. I'll add those when I add my JDM front bumper.
Entropy....that was hilarious.
Originally Posted by My Fairlady Z
he wants a n/a cuz he likes the constant power, we have already talked about this ZXDude...
Hey Bardabe, I have a TT radiator if you're interested.
I just finished my rear sway bar install so when I get the wheels put back on I'll aim the headlamps.
