glassing tweed
Old Mar 23, 2005 | 12:39 AM
dr. buddha's Avatar
Z Extreme Guy
glassing tweed
well today i started glassing the tweed in my 90 na if anyone has done it or has seen this done coment plz. i will be posting pics soon.
Old Mar 23, 2005 | 06:14 AM
CanyonCarver's Avatar
Jack Of All Trades
What is glassing tweed?
Old Mar 23, 2005 | 09:05 AM
dr. buddha's Avatar
Z Extreme Guy
im sorry i am fiber flassing all the tweed in my intireor in my z32. so i can paint it the same color as the body of the car.and put some stareo componits in it.
Old Mar 23, 2005 | 10:10 AM
RPS13_GZ32's Avatar
good luck, ive tried it before in two of my other cars and not only was it an endless endeavor but there were some difficulties w/ the fiberglass not adhering in some of the corner areas, my suggestion: use a lot of resin, like drench it in the **** and make sure it is ****in on there good, and try not to use too much hardner otherwise it will start to crack in the heat of the sun.
Old Mar 23, 2005 | 12:54 PM
dr. buddha's Avatar
Z Extreme Guy
i gust finished the first panel. this was not that hard.
what i did and mutirels so far.
things needed to do project:
1: fiber glass reson
2: 6 inch. da palm sander
3: 80 grit, 120 grit, 320 grit for the da
4: 320 grit for hand sanding
steps
1: clean tweed and rens completly and let dry
2:lay fiberglass reson down on the tweed.(no fiberglass matting is needed. the tweed will act like fiberglass matting. and works perfict.) repet 4 more times.
3: let set up
4: da sander with 80 grit to sand down all the high spots(you will be abel to tell where the high spots are and when they are gone.you will see the low spots that look like littel crators.)
5:repet da with 120 grit,320 grit
6: hand sand the rest for the shap and smothness
(note: im going to add a littel body filler to get the shap that i want but not to much of corse)
Old Mar 23, 2005 | 08:40 PM
Denver93TT's Avatar
I have also done this to my interior, turned out ok, you can also use Dupont vinyl color and bulldog adhesion promoter to paint all the rest of the parts. Mine survived the Vegas heat with no problems last summer.
Old Mar 24, 2005 | 12:06 AM
RPS13_GZ32's Avatar
I suppose tweed may be simpler then vinyl or plastic, sounds like the tweed helps mesh the two together. Im sure since it isnt getting hit by direct sunlight it will probably be a little more durable as well.
Old Mar 24, 2005 | 12:08 AM
dr. buddha's Avatar
Z Extreme Guy
thanks for that input.
im going to have the paint shop shoot all my glass in the interor to mach the paint on the out side i have pics of the first panel so far
Attached Thumbnails glassing tweed-pict0038.jpg   glassing tweed-pict0039.jpg   glassing tweed-pict0040.jpg   glassing tweed-pict0041.jpg   glassing tweed-pict0042.jpg
dr. buddha
Feb 6, 2010 06:35 AM
90NA300ZX
FS: 300ZX (90-96)
Sep 17, 2007 09:02 AM
91Zman
FS: 300ZX (90-96)
Aug 20, 2006 09:58 PM
Spyder Z 15
FS: 300ZX (90-96)
Apr 22, 2006 04:42 PM
justinmy300z
Feb 16, 2006 03:16 PM
