1999 front fascia
Old May 13, 2006 | 05:54 PM
faust's Avatar
1999 front fascia
i just installed the fascia and the connections for the smoked turn signals dont match up.does any one no where i can get new male ends to make it work?
Old May 13, 2006 | 06:56 PM
CanyonCarver's Avatar
Jack Of All Trades
How about the connectors that you took off with the old lights?
Old May 14, 2006 | 06:13 AM
faust's Avatar
they are completly different.there must be a easy fix cause i searched for this problem and didnt find anyone else who has had this problem.
Old May 14, 2006 | 09:31 AM
Aphrodite's Avatar
If there are the same amount of wires all you should have to do is match up the positive and negative, also you might want to check to make sure the voltage and amperage requirements for the new lights are teh same as the old ones
Old May 15, 2006 | 06:15 AM
dummy's Avatar
The new connectors should have come with your fascia. If they didn't, call the place you got it from and have them send you the new connectors...........
Old May 15, 2006 | 06:22 AM
WhtFairLadyZ's Avatar
The connectors are not the same...you will either need to see if the shop you bought the bumper from has them. Or take the turn signals down to your local dealership and have them look around and match the harness up with a repair one that they carry.
I ran into the same problem when I bought my JDM side repeaters on my Z...I had to go searching around and I discovered that the harness was similar to the turn signal plugs. SO that gave me a starting point.
booschi
Sep 10, 2008 11:58 AM
kevtt
Mar 14, 2006 08:35 PM
WichitaZRide
18
Jul 25, 2005 02:10 PM
iminsideurZ
Jun 30, 2005 11:58 PM
