what to check pre inspection; maintenance
Old Aug 15, 2014 | 10:20 PM
Gear Prince's Avatar
im about to smog my 1984 300zx none turbo that im restoriing. what to check, fix, tune,clean for it to surely pass the test? any suggestions? ive already done basic tune ups like oil change, spark plugs and spark plug wires..
Old Aug 16, 2014 | 07:26 AM
FlyingT's Avatar
Check engine codes. How hard it is to pass emission inspections depends on the state you are in. Some states do only a visual inspections, some like NH don't do it at all for a 20+ year old car, and Cali are bastards about it.
Old Aug 16, 2014 | 09:10 AM
zxguy1986's Avatar
In CT you could just take the car as-is to the test facility, pay the $20 and either pass or fail. If you fail, take it home, do your tune-up within 30 or 60 days, and take it back there again. The second test is free. My '86 Z is exempt from testing because of age. Check with the testing place to see if you have to pay for repeat testing. Around here, mechanics would tell you that if you fail emissions the first time, run the car until the tank is almost empty, add 2 or 3 bottles of Dry Gas and drive to the test again. Worth a try? The testing computers should have lower standards for older cars just to be fair - so if you fail, it won't be by much. They'll give you a print-out of your test results so you can see where it failed and by how much.
Old Aug 19, 2014 | 11:09 PM
so i took her to smog and my precious failed it.. technician said it runs rich.. what should be the cause to fail? i know theres a lot of posible reasons but what are the closest possible cause? it could be the chts, maf and o2 sensor.. anything else i missed? thanks guys!
Old Aug 19, 2014 | 11:19 PM
and when it comes to cars unfortunately im from cali..
Old Aug 20, 2014 | 01:56 PM
FlyingT's Avatar
Running rich is cause by the o2 sensor. There are different ones for the different model years, make sure you get the right one.
Here are the part numbers;
88hybrid.com • View topic - Z31 engine control computer system (ECCS) interchange inform
Old Aug 21, 2014 | 10:44 PM
thanks bro, i wonder why whenevr i start it up in the morning theres a yellow warning indicator in the middle of my the dash (im not sure if thats a check engine light). but after running it in idle for 30 mins it goes off.. ive been searching net how a check engine sign looks like in 1984 300zx but i couldnt find one. sometimes the warning comes on when i shift from 1st to 2nd gear and when it does it seem like it doesnt give the right/enough power.
Old Aug 22, 2014 | 11:22 AM
FlyingT's Avatar
Check out this site. It should show you the idiots lights for every dash of the Z31. And tons of info of the Z31.
ZBUM's New Nissan Z31 300ZX Homepage
Nissan Z31 300ZX Warning Lights
Old Aug 22, 2014 | 12:26 PM
Donn144's Avatar
A number of years ago I had to change the EGR valve to pass my 88
KasbeKZ
22
Nov 19, 2008 01:48 PM
lonito
Aug 14, 2002 02:12 PM
CCS8837
Jun 9, 2002 03:18 PM
GLD240Z
Jan 13, 2002 08:06 PM
Derick
Sep 18, 2001 08:25 PM
