VG30E to VG30E Swap?!?
Old Jul 5, 2015 | 12:21 PM
woodlandSerenad's Avatar
Lightbulb VG30E to VG30E Swap?!?
Hello all. I recently purchased an '85 2+2 (N/A) that the frame has nearly completely rotted out on, although the engine is fine and showing 150+ PSI on each cylinder. Now, I found even more recently, an '85 Coupe (N/A) with a blown engine. My question is, would an engine swap really be as easy as it sounds? Just pull from the 2+2 and bolt it into the coupe? The only other question I have is of the driveshaft if I were to use my 2+2 trans, even though both are the stock 5-speed. Would I be able to use the driveshaft from the coupe without any problems?
Also I realize that interior questions shouldn't be posted in the technical subforum, but would the 2+2 (front) seats bolt into the coupe body without a hitch? I would like to keep the fold-up passenger's seat for luggage purposes.
Old Jul 5, 2015 | 07:58 PM
ken99's Avatar
Both manual, both NA, both same year. Unless one is a California car and the other is Federal, should be a straight swap. Both cars should have the FS5W71C tranny. The coupe drive line will work just fine.
Only four bolts hold each front seats in. While I think the swap will work, it will not take long to find out for sure.
Old Jul 5, 2015 | 08:00 PM
Alright, good news on both fronts. Thank-you!
Da0R30
Oct 28, 2009 08:36 AM
Kidcorona
Jun 17, 2007 10:31 AM
danekicker23
Jun 25, 2005 01:57 PM
CanyonCarver
May 21, 2005 07:06 PM
adamvann3
FS: 300ZX (84-89)
Dec 4, 2004 12:48 PM
