turbo minifolds
Old Mar 20, 2006 | 11:03 AM
chubbshwc's Avatar
Exclamation turbo minifolds
i need turbo intake and exhaust manifolds in order to turbo my car anyone got something
Old Mar 20, 2006 | 12:15 PM
jfairladyz's Avatar
Check the classifieds over at Hybridz.org. There's usually some stuff listed on there. Otherwise I just saw both the intake and exhaust manifolds listed on ebay a couple of times just last night when I was browsing. I believe I was searcing 'Z31'.
Old Mar 22, 2006 | 10:48 AM
AZ-ZBum's Avatar
I think you need to do more research.
Only the driver side exhaust manifold is different.
Old Mar 26, 2006 | 09:33 AM
chubbshwc's Avatar
well
i just so happened to lose a bid on the driver side so im stuck with the passenger side manifold and why isnt it on both side because wouldnt a turbo on one side cause more back preasure on one side causin uneven power out put from each side of the engine
Old Mar 26, 2006 | 10:10 AM
AZ-ZBum's Avatar
the Z31 was only a single turbo. both sides feed the turbo via that crossover pipe.
open your hood and look.
Old Apr 30, 2006 | 11:26 PM
Phreakdout's Avatar
Quick question: I have an '88 SS in which I'm replacing the original T25 with a modified T3 from the pre- 4/87 engine. I have the early model cast down pipe but will this turbo flange fit to my driver's side manifold?
I will get the new turbo in a couple days. I'm just curious if I need to be looking for a new driver's side manifold.
Old May 1, 2006 | 12:46 PM
AZ-ZBum's Avatar
all turbo Z31s use the same exhaust manifolds. no difference.
but you will need the appropriate turbo to TB pipe.
Old May 2, 2006 | 12:27 AM
Phreakdout's Avatar
Thanks AZ. As usual, you 'da man!
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
teamadidas
Jun 2, 2005 04:41 PM
