Are these ECU's the same?
I have a 87 NA 5spd. That has a lack of power problem after the engine warms up. Posted before asking if anyone knows why the car would run great when cold and loses some power when warm, but got no answers. I have done more than a full tune-up, as well as tested as many of the sensors I could. even replaced some of them.
A friend of mine had a spare ECU from a 86 NA 5 spd, PN A18-650M24 and mine had the correct number of A18-676M80. maybe it's me wanting to solove the problem but the car appears to run a little faster now that I swapped the ECU's. Does anyone know if differant yrs of ECU's might of had differant software/programing?
This car is like new inside and out and is worth fixing. It's like show room new.
Thanks
Chris
Thanks
Chris
Guest
Posts: n/a
mine did the same thing..checked sensors, ecu, vac leaks, Fuel system etc..
CHECK YOUR TIMING...mine ran great cold...like a dog when warm...
she was 4 teeth off on one side,.. and 3 off on the other... new belt, pump, tensioner...she's back!!! running strong!
Thanks
I know the timing belt was replaced not long ago, but before I bought it. I'm suprised your car ran at all with the timing off that much.
So yours ran good cold and like $hit when it warmed up??
I have replaced almost all the sensors in the car and done a full tune up. Maybe when I get time I'll pull the timing belt covers off and see what it's set to. This problem is on the red car in my sign. It's like new in and out. So worth fixing.
Right now I have the silver Turbo in the shop, just put the engine back in after putting new main and rod bearings in it. can't wait to finish it. Still have to hook everything back up.
Thanks
Chris
Thanks
Chris
Originally Posted by AZ-ZBum
O2 sensor is different for the 87 and 86.
http://www.zheritage.com/index.php?page=leansurge
does the 87 ECU work with the older oxygen sensor but the older ECU will not work with the 87 oxygen sensor?
