is there a way you can repair a window motor instead of replacing it
Subscribe
May 21, 2006 | 06:27 AM
Is there a way you can repair a window motor instead of replacing it or does another car brand or nissan/datsun brand window motor work ... $140-$190 per window motor is a little high, I need 2 ... I saw the ones on ebay for like $50 but I don't know if I trust them
Reply
May 21, 2006 | 08:41 AM
It depends on whats wrong with the motor. If its a corrosion problem then yes you can repair that. If it's loose or broken contact somewhere then that can also be repaired. Technically anything on the motor can be repaired but finding the parts to do so is not always possible. Try a local junkyard for another used one. Self service yards are pretty inexpensive. bring a battery with you and you can test the motors to make sure they are good. If you dont want to lug a battery with you then I know yards like pick a part offer a guarantee. If the part doesn't work you can bring it back.
Reply
Subscribe
