Pulley Fit up question
I'm swapping a pre-3/87 VG30ET engine into a 88 Turbo. Of course the crank snouts are different lengths. (Why did they change this?? :102:)
Recommendations? - I assume I need to swap the balancer and crank pulley for early model. - Did the belts type change as well? (Ribbed vs. V Belt) If so, then I assume power steering pump, water pump pulley and alternator need to change? Any info is appreciated. -Gracias *EDIT* Does the pulley seperate from the damper? |
