i need help with gauges
Old May 8, 2010 | 08:49 PM
buchie620's Avatar
Smile i need help with gauges
hello drivers so i need some help with my 1984 nissan 300zx, i am installing some gauges and i was connecting my oil presur gauge and when i connect the 12volt power the gauge gos over 100psi and the stock gauge dropps. i connected the the cable to the wire nexted to the oil filter and thats wat it does, i have the digital gauges so i was woundering if i have to run new lines or wat PLEAS HELP thanks
Old May 9, 2010 | 12:19 AM
With the aftermarket gauge, you have to use there sender.
Old May 9, 2010 | 06:52 AM
260zturbo's Avatar
Stupid Hurricanes...
whats wrong with your stock digital cluster?
Old May 9, 2010 | 10:05 AM
buchie620's Avatar
im changing them to aftermarket gauges, and when i connect the sender line from the gauge to the oil pressur sensor (next to the oil filter) the dash reads 0psi and the aftermarket gauge will read past 100 psi. does any one know how to connect aftermarket gauges or has a diagram on how to connect. i have the diagram from the autometer box but its not specific enough.
Old May 9, 2010 | 01:17 PM
You HAVE to use the autometer sender. run a keyed positive to the positive terminal on the gauge and run a ground and run a wire from the gauge to the autometer sender.
Old May 9, 2010 | 02:41 PM
buchie620's Avatar
wont work i tryed that already, do u think that the gauge has ben damegged or is it that im just not doing it right
Old May 9, 2010 | 04:01 PM
260zturbo's Avatar
so you have taken the stock oil pressure sending unit out of the block and replace it with the auto-meter pressure sending unit? was it still reading high? the instructions are all pretty much straight forward.
Old May 12, 2010 | 10:19 AM
buchie620's Avatar
its got the stock oil pressur sensor should i replace it with an aftermarket one to
and if so do u have any suggestions for wat kind i should get.
Old May 12, 2010 | 01:26 PM
260zturbo's Avatar
Originally Posted by hoov100
you have to use the autometer sender. Run a keyed positive to the positive terminal on the gauge and run a ground and run a wire from the gauge to the autometer sender.
dragonwiddd
Feb 9, 2012 08:19 PM
rtmorgan
Feb 6, 2009 10:01 PM
apollo
May 7, 2006 12:00 PM
TX_zx
Apr 24, 2003 06:14 PM
datto
Feb 28, 2001 01:06 AM
