how do you disable, unhook the factory alarm on a 86 turbo z31
how do you disable, unhook the factory alarm on a 86 turbo z31 ... no I'm not a car thief, it's my car and the stupid alarm is draining my battery it's always on or blinking or something it needs to go
Sledge Hammer!!! Or Get A Real Car An S130
the stoopit little lite on the dash does not take much juice--not even enough to register. have you checked everything else????? relays, check wires around your A?C compressor--anything not right??--the security should not be draining your battery.......
if you take it out, i could use it on one of my 2 turbos.----- try your brake lite switch--thewre is a disc that can slip out of place--keeps the brake lites on when you are nowhere the car--been there--fixed that--and the headlite mechanism--that has drained my battery, also--keep your security. i do not know how to remove it--but i am serious--if you do remove it, i could use it--pm me with details, should it be a goner, ok???? |
http://www.az-zbum.com/information.factory.alarm.shtml |
could the security lite also blink if part of the system has been removed???
it does this in both of my turbos, 1986 and 1984AE50 |
where are you--i'll get there.....
I just removed the 10amp fuse to the alarm ... problem solved.
