downpipe
Old Sep 13, 2011 | 10:22 AM
87z's Avatar
87z
downpipe
hey i was wondering id anyone knew where you could get a aftermarket down pipe for 87 300zx? also what is needed to be done for a bov that vents in the air?
Old Sep 13, 2011 | 11:29 AM
87z's Avatar
87z
Also what size wrench is need to remove pov?
Old Sep 13, 2011 | 12:12 PM
AZ-ZBum's Avatar
http://www.cmperformanceexhaust.com
Cut hole in charge pipe. Weld on bung. Install BOV.
A big one. If you don't have a fixed wrench of that size, perhaps you should try a crescent wrench. You need someone to turn it for you as well?
Old Sep 13, 2011 | 12:21 PM
Flacster's Avatar
Something tells me you don't need any of these things >.>
Old Sep 25, 2011 | 04:50 PM
87z's Avatar
87z
This is my first import. I'm more of a muscle car kinda guy ya know.. And this is my first car that has a turbo.
Old Sep 25, 2011 | 07:09 PM
Flacster's Avatar
You dont need a bov if you dont have an intercooler. Do you plan on adding one?
Old Sep 25, 2011 | 09:12 PM
eh? Why specifically is an intercooler needed for a bov to be needed? A bov bleeds off excess pressure when the throttle body is snapped closed... why would an intercooler be needed for that? I'm not saying an IC is or is not needed... but your advice makes no sense.
Old Sep 25, 2011 | 10:02 PM
Flacster's Avatar
Your right about what its used for but the times ive seen it on a z31 have all been on intercoolers. Thus why i gave the answer i did. I havent seen an example of one being used without an intercooler and with a boost controller i imagine. Only other scenario i can think of.
Old Sep 26, 2011 | 08:49 AM
87z's Avatar
87z
Sorry I have an intercooler already and I have an hks recirculated bov already. And btw it's set at 10 psi from spring not boost controller and the reason for askin is I deffinatly need an exhaust cause mine is rusted out on the bottom. And I wanted to take off the pov so I can get the full 10 psi instead of just having it releasing the extra 2 psi
Old Oct 7, 2011 | 09:11 AM
Z31Turboed's Avatar
The first "Muscle Car" engine was a Rocket88 in 1949 and made an astounding 135hp at the crank and approximately 98rwhp.
So what do ya call a z31 that beats up on a modern "Muscle car" ?
A Badass Car.
Old Nov 1, 2011 | 10:47 AM
87z's Avatar
87z
I appreciate the help and I really like my z31 but I still like my z28 better.. The feeling of te ground rumble when it's running and having enough power to lift the front wheels doesn't hurt
Old Nov 1, 2011 | 11:19 AM
AZ-ZBum's Avatar
Good. Sell the Z and go back to your Camaro.
Coyote
May 13, 2013 01:06 PM
gryt57
Nov 18, 2010 08:59 PM
lilt304
Jan 2, 2010 08:25 AM
thxone
Jun 23, 2008 01:07 PM
SHWAZ300
Feb 7, 2005 02:37 PM
