boost issues
boost issues
I have an 86 300zx turbo. I'm having issues with my boost. When I'm at higher rmps it'll boost hard and pull great but every time I shift it falls on its face and takes a bit to build its boost back up, terrible situation for long pulls. I'm not sure what could be causing this, I was thinkin my wastegate out of adjustment or my blow off releasing too much pressure, any ideas would be great! Thanks!
Welcome to ZDriver!
Pick up a freebie factory service manual at XenonZ31 Reference along with the other docs. Your FSM has a lot of tune-up, inspection and repair pages that could help. Check 'em out.
Sounds like you're getting the boost you expect (did you add a manual boost control and a new gauge? Great mod for the '86T and not expensive, lotsa write-ups on it. Just don't boost too high or you blow seals/gaskets) but your between-shift RPMs are dropping off too fast. Never had that prob but somebody here has and knows what probably causes it. Doesn't sound like a major repair to me). RPMs should drop a bit but a quick shift catches 'em still high enough..)
Thanks and welcome again!
I do have manual boost adjust, i'm only running 10psi due to its a recent purchase and I don't know what the guy has done. I also have aftermarket gauge. I just can't figure out why its falling on its face for so long between gears. I have a small manifold leak I'm fixing this spring but it isn't bad enough to lose that much boost.
For the air reg check out diag EF&EC-3 in your manual. The air reg is hanging out on the right side of your injector plenum. The solenoids are the idle-up one and the fast-idle-control (FICD) See the diagram to locate.
No, wait. That's for my 86NA. You quick-check if they are working by removing them from the reg, disconnect them, apply your volts to one end, ground the other and listen/feel for the click. You can feel it working. If nothing moves, it's dead. Gotta be replaced. I had to buy a whole recycled regulator to get them - but there may be another way now. They are like $5 parts - if you need them. Check that out for starters.
But for your turbo (VG30ET) the diagrams show something else. Check out EF&EC 7. Has a different air reg. Fast idle is there but with air control AAC valve. Check it out anyway. Maybe only one solenoid there - and there's a couple of other valves elsewhere. Looks like 2 or 3 valves in controlling air for combustion - judging from the diag. I would go out and check under the hood now - but it's nighttime and raining here. Try to locate those other valves for now. We can figure out how to check them. Could be a buncha stuff...
I had a sticky throttle cable once but that caused the opposite problem: too-high RPMs between gears. Check your throttle to see if it could be acting weird... Lemme think.
PSICONCEPT
Jun 29, 2007 04:01 PM
jtmny1999
Apr 3, 2003 07:40 PM
