86 300zxt
Old Feb 18, 2009 | 10:27 AM
mackytheclown's Avatar
86 300zxt
i just bought a 86 300zxt for 500 dollorsve but the car runs rought. i have to use ether to get the car to start. when it starts it doesent want to run. i got the norm for parts like sparkplug wires,cap, rotor an spark plugs. but it still doesent want to run i cant figure it out. i really dont want to take it to a shop. can any one help if you have an idea.
Old Feb 18, 2009 | 11:33 AM
KasbeKZ's Avatar
Pr0n Addict
my first advise with a poorly running z is always to check all the connections. they corrode and prevent components from working. so take off every plug, clean it, re-crimp it (what i mean is make it grab the pin harder), and put it back on with dialectic grease. after that's done, it's likely to be running better. if not, post back, and there are tests you can do on your components.
though, before all this, i should ask if you've checked the engine's essentials like oil pressure, compression, and oil level. don't try to do anything if it doesn't have enough oil pressure.
Old Feb 18, 2009 | 11:45 AM
well now that you said that their is no oil pressure. i thought i was the senser. it doesent nock when running i have to have my foot on the gas to keep it gooing but no nocking.....
Old Feb 18, 2009 | 01:53 PM
KasbeKZ's Avatar
Pr0n Addict
are you going by the gauge in the car? are you sure it's not the sending unit? you'll either need to hook it up to a mechanical gauge or get a new sending unit to find out. mechanical gauge would give a better answer.
HOLCOMB209
May 27, 2014 06:20 AM
csgt428
Apr 30, 2012 10:23 PM
1985nissan300zx
Feb 29, 2012 07:40 AM
suitcases
FS: 300ZX (84-89)
Aug 15, 2005 03:24 PM
milehiZlover
Feb 21, 2004 09:22 AM
