1987 Fuel Guage problem
Old Jan 22, 2006 | 06:39 PM
omniserv's Avatar
Has anyone had a problem with the fuel guage like this? The guage works when the tank is full, than after driving 60 miles or so( maybe a 1/4 tank) the guage drops to empty. I just got this car last night and do not know if the sub guage works or not. I do have a wiring dia. and it does not show that there's much to it.
Just thought I'd ask if anyone has any idea's before I pull the tank. I hoping it's a bad ground or wire???
Thanks
Chris
Old Jan 22, 2006 | 07:38 PM
AZ-ZBum's Avatar
Common problem. Replace the fuel level sending unit. You don't need to pull the tank. You just lift up the rear carpet and the pad.
Old Jan 22, 2006 | 07:52 PM
FreeLanceBum's Avatar
Mine has that problem too, on a digital dash.
At about half a tank, the quage says empty, then when it hits the 5 gal. mark the sub guage works just fine.
I just got used to it, freaked me out the first day I had it though. Flew to San Diego to buy it and then drove it home to Phoenix.
Old Jan 23, 2006 | 03:07 PM
omniserv's Avatar
Thanks for the info. I wonder if there's a after market sensor for it?
I guess I'll find out if the sub gauge works. Hope I'm not walking, maybe I'll put a 1 gal. can in the back when it should be close to running out.
Thanks again,
Old Jan 25, 2006 | 11:54 AM
AZ-ZBum's Avatar
Thanks again,
Sure there is. If you want to add an aftermarket gauge.
Old Jan 27, 2006 | 12:54 PM
FranksZ31's's Avatar
fuel guage
AZ is correct, but Digital dash takes a different kind, same location. What you can do is Take yours out disconnect, take appart and clean it with a solvent(Nail Polish Remover). The fuel over the years creates a form of grime and does not allow the float contact to read correctly. You will understand once you remove the unit to clean. good luck
md90036
Dec 21, 2011 05:23 PM
DSR300zx
Aug 14, 2006 08:34 PM
Carl's Z
May 11, 2005 11:30 AM
tyco1983
Sep 11, 2002 11:26 PM
SwiggA88zxt
Aug 21, 2002 01:19 PM
