Z31 alternator not charging battery
Old Jun 13, 2011 | 12:22 AM
Samurai-Z32TT's Avatar
Ok my little brother just bought a turbo Z31 and for some reason the alternator wont charge the battery. When we bought the car the owner said that he changed the alternator and battery and it still wont hold a charge to be able to run the car for long periods of time. Any suggestions on what it might be? Would it be a hard job for us to do? Where should i look and what should i look for? Any advice on this would really help! Thanx!
Old Jun 13, 2011 | 01:59 AM
AZ-ZBum's Avatar
So replace it. It's VERY common to buy a bad alternator from auto parts places. That's why you ALWAYS have them test alternators and starters BEFORE making your purchase.
Old Jul 11, 2011 | 01:18 PM
TyMach87ZX's Avatar
Like AZ said it is very common to buy a bad alternator i just had to put one in my 87 300ZX. It is a pretty easy installation if you have a lift, if not its just a pain to do it on the ground. Also i noticed it my connector there was a little bit of corrosion, if you run into that clean out the corrosion and make sure the connector snaps into place correctly, and when u tighten the tension on the belt its always better to have less slack then to tight u can just go back and make adjustments
Old Jul 11, 2011 | 06:58 PM
Flacster's Avatar
Took me like 30 mins to replace it from the top. Just move the fan shroud, fan, belt, etc, and your there.
Old Jul 12, 2011 | 06:43 AM
omniserv's Avatar
Download copies of the FSM and Haynes manuals here.
http://www.xenonz31.com/reference.html
There's sections in both about charging systems. Read read read.
Old Aug 26, 2011 | 05:37 PM
z_man365's Avatar
true it is the first thought to replace it but y spend money not needed check your fuseable link first
Old Sep 1, 2011 | 01:22 AM
SkillZ's Avatar
Have you made any large eletrical changes? (Stereo, amp, subs, iPhone charger, etc.) There's an easy mod. To. Larger Maxima Alternator. Check ZBUMs site.. I think he has the bracket and year of alternator to purchase.
mcge8241
Dec 20, 2013 04:03 PM
BrownBomberZ
Apr 27, 2012 02:02 PM
ern
Oct 22, 2010 10:55 PM
Sixer
Apr 15, 2010 03:59 PM
jk11blueboi
Jan 26, 2010 01:08 PM
