up grade to my 300na turbo
Old Feb 20, 2002 | 04:59 AM
Spot's Avatar
Re: up grade to my 300na turbo
you will have to replace (at the very least) the following:
front crossmember, ecu, efi harness, intake piping.
you will need to relocate the alternator to the pass side.
turbo radiator is larger than na one.
Heads are different on na and turbo engines - turbo cars run lower compression than na's.
very inadvisable to slap a turbo onto a na car. definately not 'cost effective' unless you find a turbo car for cheap (less than 500$) with maybe a trashed body but good engine and stuff. then it might be worth swapping everything over.
Old Feb 21, 2002 | 10:24 AM
Spot's Avatar
upon rethinking, i believe the heads are the same, but it's either the pistons or the valves that are different. either way still easier to swap the entire engine or buy a turbo car.
83 zxt
May 1, 2007 01:32 PM
myxtaz
Feb 18, 2006 05:33 PM
blkthghts
Sep 7, 2003 07:19 PM
Zbandit
Aug 16, 2002 09:21 PM
