The unforgiving Z
Old Oct 21, 2002 | 09:08 PM
duckyz's Avatar
Re: The unforgiving Z
Well, first of all, there may be many problems...not just one. Let's tackle one. Disconnect the recieving side from both the tranny and the cooler (I have a turbo so your location may vary), from the right front side underneath the raidator-- the cooling unit looks like a mini raidaitor-- toward the bumper. If you can blow air through the line, then you need a new cooler, or try to flush it out. Hope this helps!
Old Oct 22, 2002 | 07:20 AM
Spot's Avatar
try unbolting the banjo bolts that hold both in/out cooler lines to the transmission. put compressed air through one and if it doesnt come out the other end, you've got a clog in there (be aware that any tranny fluid that's in the radiator cooler will come gushing out first - have a drain pan handy).
I wouldnt advise trying to run air through with either attached to the tranny - there may be a check valve inside the transmission or something. Plus, it's probably not good to fiill your fluid passages inside the transmission with air.
If it's clogged, separate the hoses going ot the bottom of the radiator and check them individually. if one of them is clogged, check for any bends or smashed areas in the metal lines. you can try running a flimsy coat hanger through as far as you can, and maybe dislodge whatever might be plugging it.
Old Oct 22, 2002 | 11:41 PM
duckyz's Avatar
Well, a Haynes manuel (that you can pick up at any parts store.....you may have to order it...) would be the place to go. You don't want me to explain all of that.
Old Oct 24, 2002 | 10:51 PM
Spot's Avatar
it will be loads of fun, there is no drain plug. just unbolt the pan and it will pour out... seriously, there is no drain plug. here's a bit of advice though, let the rear of the pan break loose first, and have a large drain bucket handy.
spot
