Turn signal problem
Old Nov 27, 2013 | 09:07 AM
z31Nightshift's Avatar
Unhappy Turn signal problem
My turn signal switch is bad and it's causing a short and my right head light is turning on by itself. But it's only the right light it doesn't even pop up the light just turns on I replaced it when I went to the You Pull and Pay but it's only a little better it's controllable. But I guess what I'm asking is if anyone has a spare turn signal that they would be willing to sell me cheaply?
Old Nov 28, 2013 | 10:00 AM
Hpjc10's Avatar
look on ebay, tons of z stuff
Old Dec 11, 2013 | 06:56 PM
Omegalos's Avatar
you have to clean underneath the copper strips between the contact and the copper strip with fine grit sandpaper. its behind the clear plastic shield on the blinker unit. you will see them when you pull it out again. make sure you clean it good i had to do it twice. i think there is a youtube video of somebody cleaning one. but im not sure if it was for a z. its all the same though and you obviously know how to remove the unit so you should be fine.
ZachZ-
Dec 28, 2012 12:37 AM
gdcat51
Jun 27, 2009 12:15 AM
brad101010
Mar 17, 2006 09:48 AM
JDsmash
Aug 12, 2005 11:30 AM
AlongCamePeter
Aug 22, 2004 07:31 PM
