T-top leaks
Old Dec 21, 2008 | 05:40 AM
zfever's Avatar
T-top leaks
So does anyone know whats up with the leaks? I have heard the "drain tubes get stopped up" - I cannot seem to see where the water is coming from. its coming in the rear seal, weatherstrippings good, seals seem tight, ??? Help?
Old Dec 21, 2008 | 08:46 AM
KasbeKZ's Avatar
Pr0n Addict
pour some water over the drain hole and see what happens. if it doesn't drain, blow it out with an air hose. if it does, replace the t-top seals.
Old Dec 21, 2008 | 08:54 AM
johnZboy's Avatar
Distinquished Guest
Smile Big Drip....
Welcome to the world of leaky z cars...
Many times the door glass will leak at the top, rear of it's seal. There are door glass adjustment screws inside the door that will change to angle of the glass just enough to tighten up that upper, glass to rubber, seal. You may want to look at that.
Even if there is no damaged rubber, you can bet it has dried, shrunk, and lost some of it's ability to seal properly. Buying new will be costly, if you can even find any. Nissan will tell you those seals, and many others, are obsolete parts.
Old Dec 21, 2008 | 10:07 AM
hughdogz's Avatar
My 260z has those cheezy pop-up moon roofs that leak. What I do is coat the rubber with Vaseline and it seals them up pretty good. I think the petroleum jelly might actually expand the rubber a bit too.
So far, it hasn't dissolved the rubber and it stops the leaking.
Old Dec 21, 2008 | 10:10 AM
KasbeKZ's Avatar
Pr0n Addict
that's awesome. i'm trying that on my z32. how often do you do it?
Old Dec 21, 2008 | 11:14 AM
hughdogz's Avatar
Once a year is about good...
When it stops raining, I usually open it up, and the sun dries it out after a few times. Then it may leak again.
Just keep the rubber "moist" before it rains, LOL!
Old Dec 21, 2008 | 12:49 PM
SpeciallySpiked's Avatar
I'm a Registered User!
Rubbing some vasoline along the seals helps too
EDIT: you've already been suggested that, sorry!
Old Dec 21, 2008 | 05:13 PM
ZBRICK's Avatar
I always thought vasoline would rot the rubber seal
Old Dec 21, 2008 | 08:37 PM
Z Factor's Avatar
Lightbulb
I use silicone on the weather striping, then a coat of Aerospace 303(for it's UV protection among it's other attributes.
You can get free samples here;
http://www.303products.com/tech/inde...Product_ID=428
Merry Christmas
memphisheat
Dec 15, 2011 11:33 AM
KingDatsun1
Oct 25, 2008 10:33 PM
2.8.0.Z.X
Mar 12, 2008 05:17 PM
CWHammer
Jul 17, 2004 10:36 AM
austin
Aug 19, 2002 06:34 PM
