Starting in the morning
Old Aug 20, 2003 | 10:27 AM
86ZXTurbo's Avatar
yes but where in the engine bay is it located? if its cheap Id like to replace mine too....
Old Aug 22, 2003 | 02:50 PM
Spot's Avatar
There's not a 'cold start valve' on 300zx's. the 280z and zx's had a 'cold start injector' which our car's don't have though. This could be what others are referring to as the 'cold start valve'.
You do have an air regulator though, which is supposed to help with cold starts. Your cylinder head temp sensor could also be a culprit. you can check the ohms on either of them, or try running the engine codes and see if it calls out either of these.
the air regulator is on the passenger side of the upper intake plenum, toward the rear between the egr solenoid and the pcv valve. it has a 2-wire connector going to it.
the chts is behind the timing belt cover backplate, below the distributor. it's a royal pain to get to, but you should easily be able to disconnect it's subharness from the main harness in order to check the ohms on it. the connection to the main harness should be near the #1 spark plug - it's a black squarish connector with 2 wires.
NismoPick
Other Cars
68
Apr 1, 2013 10:30 PM
iamericgee
Jul 16, 2012 09:48 AM
hoov100
Jun 14, 2006 09:11 AM
joetemp75
Jul 10, 2005 08:51 PM
ratedZ
Aug 29, 2001 08:34 AM
