Power Window and Seats
Guest
Posts: n/a
I just got my Z back from the paint and body shop.
When I was there. I remeber letting the powere seat
back and the door was left open. Then they left the
lights on later. The battery gave out and had to jump
it off. I had to unhook the turn signal because it
was bad. Now, every 5-10sec a twitch is coming from
the contact switch (Right obove the fuse box by the drivers side foot panel). I took it back out and the lights
don't twitch no more but the windows nor the seats
still don't work. Please help.
Hot-N-Tex
Re: Power Window and Seats
Sheesh, what shop did you take it to? (so's I know where NOT to go). Find out what's making the noise, which relay and replace it. Also check your fuse for the seats and windows. Try cleaning the light switch contacts (under the thin plastic piece on the backside of it) and will probably fix your turn signal switch.
