please help 87turbo
Guest
Posts: n/a
please help 87turbo
I have a couple of problems iam hopeing you guys can help me with. My first one is i had my ac charged but something wont let the cold air blow in and my second question is will a throtlebody off an 91 240 really give me more power if not what year do i need and finaly my dashboard lights went out can anyone help?
300zx 4 life baby
300zx 4 life baby
Re: please help 87turbo
I dunno about the a/c thing but most likely a bad vac hose or the blower motor if the system is properly charged. Didn't the shop check it when they serviced it? The 240sx tb isn't going to give any noticeable power increase but yes it's the 89-91 w/ ka24e code. The Stanza is 60mm also and much easier to use. Maybe Spot will answer the dash question.
ZenArcher
ZenArcher
for the dash lights, check the power supply (that's if you have a digital dash). If your dash is analog, then I don't know what that could be. actually I do, but cant' seem to remember what it was that i did which fixed it. It's been a couple of years... (now where'd I put those memory pills...)
Guest
Posts: n/a
are the rest of your lights on outside the car? if not, either a fuse or the headlight switch. If so, it could be a short or the illumination switch.
http://zbum.nissanpower.com
