overheating need help!
Old Jan 14, 2013 | 06:49 PM
bslane27's Avatar
this is my first post guys so please take it easy on me . i have a 1984 z31 turbo and i am really lost with this issue...my car starts up fine runs and idles normal boost is strong but after about 15 minuts of driving it she starts to overheat so i checked the coolant and the overflow was full but radiator was dry so i let the car cool down filled it up with coolant and 15 min later same thing radiator is dry overflow full and a bunch of coolant sitting all over the bottom of my engine bay. i replaced the radiator cap..no difference. also theres a rusty looking coating when i open the cap all over what i can see inside the cooling system. and im not shure if this has anything to do with it but when i shut the car completley off some weird fan turns on in the front drivers side part of the engine bay and it looks like something should be connected to it but nothing is there...please help me out or at least point me in the direction of what to do next or what parts i need thanks guys
Old Jan 15, 2013 | 04:50 AM
reddzx's Avatar
You may have a bad head gasket, combustion cylinder compression could be pushing coolant out of the system into the overflow.
Old Jan 15, 2013 | 06:43 AM
Steve260Z74's Avatar
How does the oil look on the dipstick?
If you're adding antifreeze to the radiator, smell the exhaust and see if you detect a sweet odor.
Do you notice a lot of white smoke from the exhaust?
Do a compression check, too.
Tips: Symptoms of a Blown Head Gasket | eHow.com
Old Jan 15, 2013 | 08:07 PM
ken99's Avatar
Sometimes folks over look the simple things. Check the drive belt on the water pump pulley. Could be loose, slipped off or completely broken. Easy to over look on cars using electric cooling fans (which is the noise you hear). If the oil looks good and compression checks out, this could also be a corroded/plugged radiator, hence the rust you see.
Old Jan 16, 2013 | 07:03 AM
Mishimoto's Avatar
Are you able to see where the coolant is coming from when you say it is all over the engine bay? See if you can clean off the coolant and run the car while watching for the location of the leak or where the coolant is coming from. This should give a few clues.
Old Jan 22, 2013 | 09:28 AM
bslane27's Avatar
thx
it looks like some is dripping from the bottom of the engine below the water pump im pretty shure the oil looks fine i orderd a timing belt water pump thermostat and radiator but think i im just gunna rebuild the whole motor i want it to run like new anyone got a list of things i need to buy for a full rebuild?
Old Jan 22, 2013 | 11:55 AM
rogerz's Avatar
Grumpy & Helpful
get the kit from courtesy nisssan got everything you need.
BlueKitsune
Dec 5, 2010 02:42 PM
ZXT83
Apr 7, 2010 06:06 PM
my86z
Sep 16, 2006 08:41 AM
lillievickers
Sep 18, 2005 10:59 AM
Shameless
May 18, 2004 06:44 PM
