neutral safety switch
Need help
Hey guys I got a 87 300zxt something with the clutch inhibitor is messed up. It doesn't start. Usually I can play with the clutch and it will start but it's not doing it this time. Please help asap
it could also be your neutral safety switch. test both of them, test the relay to see if the magnet contacts and lets current through. if it does, check the neutral safety switch, it might be stuck open. and if that doesn work then check the grounds on both =)
i thought neutral saftey switches were for auto..? i have a 5 sp and having problems starting it. have to play with clutch while key is turned to start. any ideas? where is the neutral safety switch located?
yes... clutch switch, my bad. Noboosts130 got the correct term.
There is a neutral safety switch, but I've yet to see any proof it does anything. It's located on the transmission. There are two switches. One is the reverse switch. The other is the neutral switch.
Well the relays I got weren't the right ones... No one has the right ones I guess it's something u gotta get from a Nissan dealer? And I was looking on the Internet and seen someone jump the wires from the clutch inhibitor switch (I have a brand new one) to a harness just above it and says it works. Does anyone know if this will work and what wires I need to put together?
If you come on here asking for advice and don't take our advice/ignore our advice, then you should really just stop posting about your problem and ignore us completely.
