Need Help
Old Oct 12, 2003 | 04:01 PM
johnZboy's Avatar
Distinquished Guest
Reset throttle position sensor???
Old Oct 12, 2003 | 09:02 PM
dkrzan's Avatar
i suggest you get a haynes manual for this troubleshooting.
i had to reset the tps just recently cuz i put on a 240sx throttle body.
from the haynes manual:
1 loosen the retaining bolts
2 with engine idling at normal temp, confirm engine is in normal idling specifications. if not, correct idle speed.
3 with the tps connector disconnected connect an ohmmeter to the top two terminals.
4 rotate the tps counterclockwise and the meter should show no continuity.
5 rotate the tps clockwise until continuity is established, then tighten the bolts.
6 replace the connector.
before i had to adjust this i noticed my car seemed to run normal with it unplugged.
good luck
Old Oct 12, 2003 | 10:14 PM
dr. buddha's Avatar
Z Extreme Guy
ok first things first
1- did you dis conect the bat. when you did the upgrade?
2- if you did not next time do so.
3- to reset the tps and computer disconect the bat. and wait 1 - 2 minets and reconect it.
4- the problem might be your exsast may not have enght back presher this can be a big problem.and could be the reson car may not stay runing. one guy ont my car club hade same problem and he had is exsat redone and it fixed his idel problem
Dr. Buddha (owner of z extreme)
