ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   Maxima engine swap quality (https://www.zdriver.com/forums/300zx-z31-forums-8/maxima-engine-swap-quality-411/)
killermonkeys May 31, 2001 04:59 PM
Hey, someone is selling a z31 with a maxima engine, and I need a car pretty badly. The price is definitely right, but I'm wondering how well the maxima's engine performs in the Z. I can find out more about it if more info is needed.
Spot May 31, 2001 07:03 PM
Re: Options on the car
I can run the vin and tell you what options it was supposed to come with.
As for the maxima engine, it's the same one used in non-turbo z31's so it should be at least as realiable. my '86na has 235k on it and was running good when I pulled it out (gonna put a turbo engine in it's place :) )
Engloid86T Jun 11, 2001 07:08 PM
Spot, you sure get around...lol
Maxima intakes are different, as are the plenums. Probably both have been swapped out from the Z engine to the Max engine.
I know that I have an 87 maxima intake manifold here. THat model was rear wheel drive, so the engine was in straight. The upper holes are larger than on my 86 turbo Z. Lower ends look the same.
Engloid Jul 22, 2001 05:56 PM
I didn't notice that, but now that you mention it, my 92 max does have the oil tube on the other side of the block.
